POV-Ray : Newsgroups : moray.win : HELLLPPPPP! Server Time
11 Nov 2026 20:48:43 EST (-0500)
  HELLLPPPPP! (Message 1 to 8 of 8)
Subject: HELLLPPPPP!
Date: 21 Feb 2002 19:43:29
Message: <3C759440.A63FE4C3@scifi-fantasy.com>
3DWin.  Import 3DS file, export RAW file.  Open in Moray.  Whoops,
CAN'T open in Moray, it has to be converted to UDO first!  3DWin.
Import RAW file, export POV/UDO files.  Open in Moray.  Good.
Render.  CRASH-OLA.  POV freeze, giving error about inability to open
thisorthat_m.inc.  It's right there!  Looks fine.  WTF?
Tim Cook
Version: 3.12
Subject: Re: HELLLPPPPP!
Date: 21 Feb 2002 20:05:09
Message: <3C759948.5ECE904C@pacbell.net>
Are you using POV-Ray v3.5?
If so, do you have the security settings set properly in POV-Ray v3.5?
Ken Tyler
Date: 21 Feb 2002 20:37:40
Message: <3C75A0F3.35F7EC96@scifi-fantasy.com>
> POV-Ray v3.5?
Yes and yes.
Tim Cook
Version: 3.12
Date: 22 Feb 2002 03:00:53
Message: <mkub7ucsflha1ek5p8ccn25g4fcpt10qh2@4ax.com>
Hi Timothy R. Cook, you recently wrote in moray.win:
Right where? Is it in the same path as your scene POV file? Or is it
in a library path?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 22 Feb 2002 03:29:09
Message: <3C760152.361EAF0B@scifi-fantasy.com>
> in a library path?
In the same path as the POV file.
Tim Cook
Version: 3.12
Date: 22 Feb 2002 12:33:27
Message: <q50d7uofnhp2sgbi53thqq2451uj2013ds@4ax.com>
> CRASH-OLA.
Moray crashes? Freezes?
> thisorthat_m.inc.
If POV freezes how can you see the error?
Does the file render outside of Moray?
- Lutz
Date: 22 Feb 2002 18:16:09
Message: <3C76D139.76D50353@scifi-fantasy.com>
> > CRASH-OLA.
> > thisorthat_m.inc.
Actually it's POV that freezes right after giving the can't read
error, causing Moray to become confused and sluggish (I've
encountered the 'POV-crash-confusing-Moray' problem elsewhere,
but don't remember what I was doing...)
Tim Cook
Version: 3.12
Date: 22 Feb 2002 22:32:24
Message: <3c770d48@news.povray.org>
see GTTree Plugin post above
Best Regards
Keith
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3C76D139.76D50353@scifi-fantasy.com...
> > > CRASH-OLA.
> > > thisorthat_m.inc.
> Tim Cook
> http://empyrean.scifi-fantasy.com
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
