When i try and use a .gif for a hight field that i made in sTile99
povray gives me
the error
test.pov.93: error: error reading data from GIF image.
I was using moray and other gifs work. what should i do?
Zac Trolley
Team Amp Member #143. www.teamamp.com
http://members.home.net/zact/
Zac Trolley wrote:
> > When i try and use a .gif for a hight field that i made in sTile99> povray gives me> the error> test.pov.93: error: error reading data from GIF image.> I was using moray and other gifs work. what should i do?
Try opening the .gif file in a normal image viewing program. If your
image viewing program can open it then POV-Ray should be able to use
it. I do not recall ever having that problem with a .gif file before
and I have used many of them for HF's in the past.
Also check that the gif is not interlaced.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););} /*- Warp -*/
if you're using megapov, i think gif support was taken out due to legal
issues. use png instead.
Zac Trolley wrote:
> > When i try and use a .gif for a hight field that i made in sTile99> povray gives me> the error> test.pov.93: error: error reading data from GIF image.> I was using moray and other gifs work. what should i do?> > --> Zac Trolley> Team Amp Member #143. www.teamamp.com> http://members.home.net/zact/
