Hi there,
got a problem with a premade povray scene i wanted to export to moray.
Now i have a texture which is using a predefined color (rgb
<bla,bla,bla>) and then uses this color as a reference, but multiplies
it.
e.g.: color*0.6
is there any way i can do that with moray or which is the correct
formula to calculate those values by hand?
Help would be appreciated
Thanks in Advance Arne Kleinophorst
Arne Kleinophorst wrote:
> Hi there,
> it.
> e.g.: color*0.6
POV-Ray as you guessed takes care of the math for you. If you need
to convert a multiplied color vector <> then you will have to do
so for each color in the vector statement.
Examples:
rgb< 1, 1, 1>*0.5 becomes rgb< 0.5, 0.5, 0.5>
rgb< 1, 0.5, 0.25>*0.5 becomes rgb< 0.5, 0.25, 0.125>
etc...
Ken Tyler
if it's more than 1.0 after you multiply like ken suggested, you can
click on the range button and set the range of the colors all the way up
to ten i think. i do it all the time.
> > Hi there,
> > it.
> > e.g.: color*0.6
> Examples:
> etc...
> Ken Tyler
well, that helped a bit, but still it's looking different, thanks
anyway. I think i can do it somehow with the accustomied range.
Arne Kleinophorst
