VMK <vmk### [at] icqmail com> wrote:
: I still find it difficult to understand how Moray 3.2 can export POV
: files in a split second (Ctrl-F9) without even opening POV-ray, yet it
: can't read the POV files it just created. Isn't it bizzarre? Imagine
: Microsoft Front Page not being able to read html files.
This is because the pov file format is not the native format of moray. What
moray does is actually export to a povray file, which is not exactly the same
as saving.
First of all: Why should moray open povray to write a pov file? Povray
doesn't write pov files, and pov files are just text. In the same way you
don't need povray to write a pov file; any text editor will be good enough
(even the text editor in winpov is not really part of povray itself, but just
a kind of add-on).
In theory it could be possible for moray to read its own pov files as long
as they are completely unmodified (because if it knows what to write, it can
easily know what to read). But if you modify the file in ANY way, or try to
read a pov file not created with moray, the difficulty of the task will be
a lot higher (just think about all those while-loops, macros, arrays...).
HTML files are a lot easier to read than pov files, and frontpage has
probably been made to have HTML as its native format.
Hi Warp, you recently wrote in moray.win:
And it sucks at it, too. It removes and adds stuff at will.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
Guys, guys, let's not turn this into a FrontPage-bashing discussion. I knew I
was going to have trouble when I mentioned it. I needed an example and I
don't know many html-editing programs except Hot Metal Pro. I personally use
EditPlus (a text editor) for pretty much anything from HTML to Perl.
I for one will cancel my reply to avoid further problems.
U da man!!! :)
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
