Yes it's possible, and you'd probably need to change the default file...
(the file that contains what all pov expotrs contain).... The only
problem will be when you'll export to soemthing else, i think...
Well, it's certainly easier than the galaxy plugin ot the column plugin
8)
Psychomek wrote:
> I would like to request a plugin that could be used with the ISOsurface
> functions in Megapov.
> I'm not to sure on how to do it. but maybe use the basic shapes for
> showing the iso surfaces and maybe a little dialog box for the formula
> (formulae).
> please if this is a too difficult task just put my idea down as easily
> as possible. in other words just explain to me why it can't or isn't
> possibly done.
> Thanks Psychomek
AKA paul_virak_khuong at yahoo.com, pkhuong at deja.com, pkhuong at
crosswinds.net and pkhuong at technologist.com(list not complete)...
Hmmmm.... I could do something along those lines but what's the point -
it's only a v.short term solution as Pov 3.5 will be out before the
end of the year ;-), incorporating some/all of the MegaPov functions
expect that they will probably change parameters, names etc..
Also Lutz will probably be updating Moray to work with the new
functions as and when he has the time/inclination.
Also you wouldn't believe the amount of mail I get because people can't/
won't read the included docs - this would quadruple at least - I'm
afraid
I'm just not cut out for this ;-)
Best Regards,
Keith
> 8)
> > (formulae).
> > possibly done.
> > Thanks Psychomek
