POV-Ray : Newsgroups : moray.win : Skin? Server Time
11 Nov 2026 22:09:02 EST (-0500)
  Skin? (Message 1 to 13 of 13)
Subject: Skin?
Date: 8 May 2000 08:53:38
Message: <3916b8d2$1@news.povray.org>
Is there a way to run "skin" over two objects that are not merged so to
speak?
ie     ***********                        **********
        *            *               +       *          *         +        a
covering image map, or what ever         *        1 piece with no solid
middle   *
I hope this explained ok, I'm making an item and would like to make a top
and a bottom and just stretch a whatever between the two.  If I can explain
this further I'll try but for know I have no idea what I'm trying to say
verbally.
TIA
Dean
Subject: Re: Skin?
Date: 8 May 2000 08:56:38
Message: <3916b986@news.povray.org>
I just opened this in OE 5 with the folders  column open, and it's pretty
messed up.  I want two pieces, a distance away from each other to share a
"skin" between them
Subject: Re: Skin?
Date: 8 May 2000 18:45:10
Message: <3917443C.D1863DC@enter.net>
> "skin" between them
First, I'll assume by "skin" you mean a texture, not a skin-like
object (for example a bezier patch stretched between them).
But do you mean you want to use one texture on both pieces at once
thus save the trouble of assigning individual textures, or do
you want it to look like they were once together, painted while
they were together, and then subsequently split apart each taking
its piece of the texture with it? Either can be done; the latter
is somewhat more complicated to explain and requires you to use
multiple references to the same texture, but is still quite
possible, but it'd be better to know which you're trying
to do before describing a solution.
Subject: Re: Skin?
Date: 9 May 2000 04:37:43
Message: <3917ce57@news.povray.org>
You should seriously consider using a fixed-width font when writing
(and of course reading) articles. Your ascii-art is pretty messed up.
Subject: Re: Skin?
Date: 9 May 2000 14:53:33
Message: <39185ead$1@news.povray.org>
I mean a texture that stretched between two seperate items (objects)
(without ansi art) an example...
 I have two spheres 10 units away from each other, not touching.  Can I use
a texture to make them into a solid capsule?  or hotdog maybe?
again I apologize for the previous mess
Dean
Subject: Re: Skin?
Date: 9 May 2000 14:54:43
Message: <39185ef3$1@news.povray.org>
news:3917ce57@news.povray.org...
the joys of using OE5 in html mode or rtf whatever.
Sorry again
me
Subject: Re: Skin?
Date: 9 May 2000 17:02:30
Message: <39187C5F.D26D037E@pacbell.net>
This is not possible. Textures can only be applied to object not to
open space.
The easiest way to do this is to simply connect the two spheres with
a cylinder object who's end points stop at the location of the two
spheres and then apply your texture to all three objects. Read the
instructions on making groups using CSG specifically a UNION.
Subject: connective tissue (was: Re: Skin?)
Date: 11 May 2000 01:17:55
Message: <391a4283@news.povray.org>
Dean MacIsaac <dmm### [at] fngpcom> wrote in message
news:3916b8d2$1@news.povray.org...
> speak?
i think what he's getting at is what i've also been wondering...of course
lightwave has a feature similar to this, and blender has a deformation
lattice that can work that way too....but i suppose the question is:  can
you use moray to connect two objects and have a smooth connective tissue
that runs across the ika joint and stays together when the joint is
bent...like the skin covering your elbow??  or, in the case of the previous
question, like two metaballs (metaobjects ??)...
jb
Subject: Re: connective tissue (was: Re: Skin?)
Date: 11 May 2000 19:29:20
Message: <MPG.13852a8a770de8829896a5@news.stmuc.com>
The quick answer is: No.
Not at the moment.
Bye for now,
     Jamie.
Date: 11 May 2000 22:06:37
Message: <391b672d@news.povray.org>
> Not at the moment.
Does that mean that Moray will have support for metaballs/objects in future
versions ?? :-)
jb
Date: 12 May 2000 08:02:26
Message: <391BF3B9.FD060D6A@mninter.net>
Its possible in the form of a plugin. No idea who is trying, or if anyone is-
the list is totally silent(or I've been kicked off. Probably the latter).
> > Not at the moment.
> versions ?? :-)
> jb
You Know You've Been Raytracing Too Long When:
 You have ever said "I don't need no stinking modelers!!!"
Produced by Alex Magidow's Sig File Randomizer(YKYBRTTL jokes courtesy of
c.g.r.raytracing)
Date: 12 May 2000 14:11:55
Message: <MPG.13865893550374ed9896a6@news.stmuc.com>
> > Not at the moment.
> versions ?? :-)
Don't ask me, I only use the program :)
I seem to remember that somebody was working on a Blob plugin, but I've
not heard anything about that recently.
And it (sort of) has blob support ATM, but only through importing /blb
files, created in blob sculptor.  And no, I don't have a URL for Blob
sculptor, sorry.
Bye for now,
     Jamie.
Date: 30 May 2000 11:07:31
Message: <3933d933$1@news.povray.org>
I appreciate you picking up the ball and running with it.  I'm new to the
world of C++, but once I've got that down plugins will be my first attack.
I love Moray as a modeler, and I'm not ready to give it up, but I'd like to
see more, and if that means plugins, then so be it.  and If I have to create
them then so be that as well.
Thanks again,
Dean
