POV-Ray : Newsgroups : moray.win : CSG operations Server Time
11 Nov 2026 22:16:54 EST (-0500)
  CSG operations (Message 1 to 14 of 14)
Subject: CSG operations
Date: 5 Apr 2000 12:06:33
Message: <38eb6489$1@news.povray.org>
I'm trying to add windows to a UDO object that I imported.
Here's what I do, and I'm wondering if there is an easier way to do it:
1. Create a CSG - call it WindowCut - apply a texture.
2. Add the UDO object (which happens to be a 747)
3. Create a box
4. Add it to the above CSG
5. Set the operation to Difference.  This creates a 'hole' in the UDO
object.
6. Create another CSG - call it 747 - apply a glass texture.
7. Add a copy of the UDO object above.
8. Add a copy of the box in step 3.
9. Set the operation to Intersection.
10. Now create a third CSG - call it 747-Parent.
11. Add the two CSG items.
Now I have a 747 object with a window.  This works, but seems to be a lot of
work and uses a lot of memory.  Is this how others do it?  IS there a better
way?
Mike
wk: mik### [at] pyxiscom  www.pyxis.com
hm: mwe### [at] sciticom  www.geocities.com/mikepweber
Subject: Re: CSG operations
Date: 5 Apr 2000 14:21:45
Message: <38EB84D3.E850D8BF@yahoo.com>
do you want to see through the window into the plane?  if so, did you
model the inside?  what is the box in step 3?  i haven't used udos
much.  are they solid?  so you have three copies of the udo?  it seems
like you should be able to do it cleaner.  answer the above q's and i'll
see if i can help.
> 3. Create a box
> object.
> way?
> Mike
Date: 5 Apr 2000 15:54:50
Message: <38eb9a0a@news.povray.org>
> see if i can help.
I do not need to see the inside of the airplane.
The box is used to cut a hole in the airplane to make a window.
UDOs aren't solid - just a bunch of triangles to make the object.
No, only two UDOs - the original, and one copy.
I agree that it should be done cleaner.
> > 3. Create a box
> > object.
lot of
better
> > way?
> > Mike
Date: 6 Apr 2000 03:50:47
Message: <rbgoeskd6njnmpflvk41uv583a71m36c3r@4ax.com>
Hi Mike Weber, you recently wrote in moray.win:
Urgh. Where did you get the UDO from (who wrote it)? Usually,
different parts of an UDO will be selectable and in a good model the
windows would be seperate entities that you could just texture with
glass.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 6 Apr 2000 10:34:10
Message: <38eca062@news.povray.org>
Lutz,
I got a DXF file from www.cadalog.com and converted it to the UDO format -
and I agree that it should have selectable parts.  Other DWG/DXF/UDO models
I've worked with have had selectable parts.  In this example I used a UDO -
but I could have easily created an object using a bunch of blobs, or other
solids.
Mike
"Lutz Kretzschmar" <lut### [at] stmuccom> wrote in message
news:rbgoeskd6njnmpflvk41uv583a71m36c3r@4ax.com...
> glass.
> - Lutz
Date: 6 Apr 2000 15:13:30
Message: <bcopes4vq1q6va3btab26dk9tkiu6cch5o@4ax.com>
That was my original question: *how* did you convert it?
> Other DWG/DXF/UDO models I've worked with have had selectable
> parts.
Maybe it's just a "badly-designed" DXF file.
- Lutz
Date: 6 Apr 2000 16:44:23
Message: <38ecf727$1@news.povray.org>
news:bcopes4vq1q6va3btab26dk9tkiu6cch5o@4ax.com...
format -
Oh - I used a DWG to DXF coverter from.... now I forgot.  Then I converted
it from DXF to UDO using Thomas Bier's utility.
> > parts.
True, but in some cases I want to perform CSG operations like this
regardless of the object.
> - Lutz
Date: 6 Apr 2000 19:43:53
Message: <38ED2162.EE07DFF4@pacbell.net>
I hate to burst everyones bubble here but CSG operations do not work with
triangle mesh objects.
Date: 7 Apr 2000 01:31:47
Message: <38ed72c3@news.povray.org>
Is the UDO a triangle mesh? I believe it is AND the CSG operation did work !
Ken <tyl### [at] pacbellnet> wrote in message
news:38ED2162.EE07DFF4@pacbell.net...
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 7 Apr 2000 04:14:18
Message: <b56rescmual7be420llriifbdiv8lsgml7@4ax.com>
Hi Ken, you recently wrote in moray.win:
Sure they do. It's just not guaranteed to work everytime, but mostly
it does work quite well.
- Lutz
Date: 7 Apr 2000 04:34:16
Message: <38ED9DB2.37A7E2F6@pacbell.net>
Finite Patch Primitives
There are six totally thin, finite objects which have no well-defined inside.
They are bicubic patch, disc, smooth triangle, triangle, polygon and mesh.
They may be combined in CSG union but cannot be use in other types of CSG
(or inside a clipped_by statement).
Date: 7 Apr 2000 10:19:00
Message: <38edee54$1@news.povray.org>
My main concern is the best way to cut out a 'hole' from a an object, and
replace that hole with a window that is flush with original object.
In other words, lets say I have a cube, a tall thin one, and I want to make
a bunch of glass windows.  First I would do a CSG difference operation on it
using a bunch of smaller cubes to cut the holes.  Then I would use the same
tall thin cube with the smaller ones and do an intersection and use the
appropriate texture.  Then a 3rd CSG would combine the above 2 CSGs. I now
realize that this is more of a general POV CSG question than Moray.  But my
question still holds - is this the best way?
In the POV script I could do (with out textures):
#declare Building = box{<0,0,0><1,1,1> scale <tall,thin,1>}
#declare BunchOfCubes = boxes
then
union{
 difference{Building
            BunchOfCubes }
 intersection{Building
              BunchOfCubes {
Assume that Building is actually a mesh of triangles or a UDO object,
this is efficient because we are saving memory by referencing objects.
Is it possible to reference objects in Moray...  Now I'll go read the Moray
help...
Mike
"Ken" <tyl### [at] pacbellnet> wrote in message
news:38ED9DB2.37A7E2F6@pacbell.net...
with
inside.
Date: 8 Apr 2000 12:56:21
Message: <38EF655C.54F8AE9@yahoo.com>
if you don't need to see into the windows, why don't you just make some
image maps to lay on the plane?
> then
> union{
>  difference{Building
>             BunchOfCubes }
>               BunchOfCubes {
> help...
> Mike
> with
> inside.
> > http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
Date: 10 Apr 2000 04:15:05
Message: <o933fs0lunbkejmtljns2ghn666j69ak0j@4ax.com>
That's what the docs say, but not necessarily what the program does
You can take a triangle mesh and difference something out of it. It
may not look like you would expect, but it does make a hole.
- Lutz
