POV-Ray : Newsgroups : moray.win : materials rendering without killing the current render Server Time
27 Sep 2024 21:19:44 EDT (-0400)
  materials rendering without killing the current render (Message 1 to 10 of 11)
Subject: materials rendering without killing the current render
Date: 30 Mar 2000 10:27:55
Message: <38e3727b@news.povray.org>
Hi All- is there a way to allow Moray to launch a second instance of POV to
render materials thumbnails and tests without killing the looooong main
rendering that POV is working on?
-Pascal
Subject: Re: materials rendering without killing the current render
Date: 30 Mar 2000 12:50:56
Message: <38E39493.B7C314EF@yahoo.com>
i think moray depends on pov having only a single instance and
automatically changes pov's settings according;y.  sorry, no luck there.
> -Pascal
Date: 30 Mar 2000 20:33:41
Message: <38E4011A.36567BE5@videotron.ca>
Yeah, well there's something there:
Whenever i try to render the same scene, the chages don't appear on the
render, like pov was still using the same scene file
Is it normal/is there a way to counter that??
> > -Pascal
AKA paul_virak_khuong at yahoo.com, pkhuong at deja.com, pkhuong at
crosswinds.net and pkhuong at technologist.com(list not complete)...
Date: 30 Mar 2000 20:47:44
Message: <38E40404.D8C4B121@pacbell.net>
> -Pascal
There is a way to work around this outside of Moray. You can run more than
one instance of POV-Ray if you go to the options menu in the POV-Ray editor
and uncheck the option for "keep single instance". You could then do your
actual render directly with in POV-Ray itself, then use Moray to start
another render of your new scene development or for such things as rendering
your materials thumbnails. Doing it this way may cause Moray to be sluggish
or even unresponsive at times, and the render times in POV-Ray will surely
suffer too, but if this is what you want to do it is not impossible to do
so.
Date: 31 Mar 2000 12:43:19
Message: <38e4e3b7$1@news.povray.org>
editor
rendering
sluggish
> so.
hmm .. and if you use NT on a dual-processor machine may be the two
instances are distributed ???
would be a nice question ... has someone tried ???
Date: 31 Mar 2000 14:39:50
Message: <38e4ff06@news.povray.org>
Well, I did try it on my old dual 300 under NT4 and I can tell you that
sluggish is not the word... Impossible is more like it. It did appear to be
ditributed onto both processors though, in that with one instance running I
had 57% cpu usage and with two megaPovs running it was 100%.
-Pascal
Jan Walzer wrote in message <38e4e3b7$1@news.povray.org>...
than
>editor
>rendering
>sluggish
surely
>> so.
Date: 1 Apr 2000 16:21:29
Message: <38e66859@news.povray.org>
Pascal Golay <cgo### [at] idtnet> schrieb in im Newsbeitrag:
38e4ff06@news.povray.org...
be
I
So is there any alternatice to make pov using more than one processor ???
Date: 1 Apr 2000 16:53:48
Message: <38E67024.48ABAC41@pacbell.net>
Read up on this subject here -
http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#multiprocessor
Date: 2 Apr 2000 13:31:22
Message: <fs0fes4vg1ejiu7qijvlhtps2jos60sh38@4ax.com>
  I knew that section of the FAQ would come in handy <s>.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 2 Apr 2000 15:49:04
Message: <38E7A469.5BAB7F1B@pacbell.net>
It's probably the 4th time I have referred someone to this section since
adding it and sure has saved me a lot of typing :)
