Subject: Wish for next release...
Date: 27 Mar 2000 12:25:18
Message: <38df997e$1@news.povray.org>
I'd like to see a translate for the camera - so both the look_at and
position parameters can be changed in one control. It would be most useful
in animations with the animation plug-in. How does everyone else feel about
that?
Mike
wk: mik### [at] pyxiscom www.pyxis.com
hm: mwe### [at] sciticom www.geocities.com/mikepweber
Subject: Re: Wish for next release...
Date: 27 Mar 2000 13:31:59
Message: <38dfa91f@news.povray.org>
> I'd like to see a translate for the camera - so both the look_at and> position parameters can be changed in one control. It would be most
useful
about
> that?
Doesn't the track funktion in the 3D-Window work like this ??
I think it was when you press [Ctrl]+[Shift] to active this mode ... or was
it something with [ALT] ??
Lutz ???
Jan Walzer <wal### [at] informatikuni-hallede>
Date: 27 Mar 2000 19:08:57
Message: <38dff819$1@news.povray.org>
Walzer <wal### [at] informatikuni-hallede> wrote
> Doesn't the track funktion in the 3D-Window work like this ?? I
... or was it something with [ALT] ??
Either left click, select track, and move or ctl-alt and then
move... only works in the window displaying the camera view, tho.
Claire
Hi Mike Weber, you recently wrote in moray.win:
> I'd like to see a translate for the camera - so both the look_at and> position parameters can be changed in one control. It would be most useful> in animations with the animation plug-in. How does everyone else feel about> that?
A good suggestion, I'll note it.
Workaround for the moment is to make the camera dependant on another
object. IOW, create a cube and make both the lookat and position
relative to that cube (use the two Set buttons on the cameras Modify
Tab). Then move the cube to move the camera. Set the Export flag on
the cube to off so that it doesn't block your view.
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Date: 2 Apr 2000 19:16:27
Message: <38e7d4cb@news.povray.org>
Thanks for the instructions - I'll give it a try.
Mike
Lutz Kretzschmar <lut### [at] stmuccom> wrote in message
news:ri21esch8ehuarm80gf1fqc6s58qtl6ua7@4ax.com...
> Hi Mike Weber, you recently wrote in moray.win:>> > I'd like to see a translate for the camera - so both the look_at and> > position parameters can be changed in one control. It would be most
useful
about
> > that?> A good suggestion, I'll note it.>> Workaround for the moment is to make the camera dependant on another> object. IOW, create a cube and make both the lookat and position> relative to that cube (use the two Set buttons on the cameras Modify> Tab). Then move the cube to move the camera. Set the Export flag on> the cube to off so that it doesn't block your view.>> - Lutz> email : lut### [at] stmuccom> Web : http://www.stmuc.com/moray
