POV-Ray : Newsgroups : moray.win : Heightfields in Moray Server Time
11 Nov 2026 22:16:46 EST (-0500)
  Heightfields in Moray (Message 1 to 7 of 7)
Subject: Heightfields in Moray
Date: 14 Mar 2000 13:26:00
Message: <38CE843C.2802C1AF@astro.uio.no>
Hi everybody,
I'm trying to use the height field object in Moray, but I'm having no luck in
getting what I want.
I have created a ghf using the Terrain Maker program, converted this to a
tga-file using
LPaser. I then use the height field object with the tga-file as a source. Using
the read button
the heightfield looks quite good, but when I render it I do not get a result
that looks like the
grid look in Moray. It seems that it just traces the lower portions of the
height field. I'm
using a flat color, so the material should not be the problem.
Can anyone help
Tommy Grav
tom### [at] astrouiono     http://www.uio.no/~tommygr/
Institute of Astrophysics, UiO, No
IMTU tn++t4+tg+ ru+ge++ !3i jt+au+st+ls hi++dr-so++zh-sy-sw++
Subject: Re: Heightfields in Moray
Date: 14 Mar 2000 14:28:41
Message: <38CE92ED.1A5D15F7@astro.uio.no>
Tommy Grav wrote:
> Hi everybody,
> tga-file using
> the read button
> that looks like the
> height field. I'm
> Can anyone help
More investigation of the problem reveals that the hightfield is as it should be,
so it is the read-button in the height field object that gives something that
appears
to be the opposite of the actuall heightfield (high areas where there should be
low and
low where the high should be). Is this a bug or am I using the heigh field object
wrong?
Thanks in advance
> Tommy Grav
Tommy Grav
Date: 14 Mar 2000 15:23:11
Message: <38ce9faf$1@news.povray.org>
Rotate your height field object 180 degrees so that it is upside-down.  Then
re-render.
Does that help?
Mike
wk: mik### [at] pyxiscom  www.pyxis.com
hm: mwe### [at] sciticom  www.geocities.com/mikepweber
"Tommy Grav" <tom### [at] astrouiono> wrote in message
news:38CE92ED.1A5D15F7@astro.uio.no...
> Tommy Grav wrote:
> > Hi everybody,
luck in
a
> > tga-file using
source. Using
> > the read button
result
> > that looks like the
the
> > height field. I'm
> > Can anyone help
should be,
that
> appears
should be
> low and
object
> wrong?
> Thanks in advance
> > Tommy Grav
> Tommy Grav
Date: 14 Mar 2000 17:59:35
Message: <38cec457$1@news.povray.org>
I guess he would have to scale it with -1 in the right direction, not
rotate it...
Johannes.
"Mike Weber" <mik### [at] pyxiscom> wrote in message
news:38ce9faf$1@news.povray.org...
Then
> re-render.
> Does that help?
> Mike
> > Tommy Grav wrote:
> > > Hi everybody,
no
> luck in
this to
> a
> > > tga-file using
> source. Using
> > > the read button
get a
> result
> > > that looks like the
portions of
> the
> > > height field. I'm
> > > Can anyone help
it
> should be,
something
> that
> > appears
there
> should be
> > low and
field
> object
> > wrong?
> > Thanks in advance
> > > Tommy Grav
> > Tommy Grav
Date: 14 Mar 2000 18:21:25
Message: <38cec975$1@news.povray.org>
That's what I thought - but the last I worked with HF (today) I tried that
and it change the value to something like 0.000001 - not -1
Mike
"Johannes Hubert" <jht### [at] mailacom> wrote in message
news:38cec457$1@news.povray.org...
> rotate it...
> Johannes.
> Then
> > re-render.
> > Does that help?
> > Mike
> > > Tommy Grav wrote:
> > > > Hi everybody,
> no
> > luck in
> this to
> > a
> > > > tga-file using
> > source. Using
> > > > the read button
> get a
> > result
> > > > that looks like the
> portions of
> > the
> > > > height field. I'm
> > > > Can anyone help
> it
> > should be,
> something
> > that
> > > appears
> there
> > should be
> > > low and
> field
> > object
> > > wrong?
> > > Thanks in advance
> > > > Tommy Grav
> > > Tommy Grav
Date: 15 Mar 2000 17:00:30
Message: <38d10832.2017861@news.stmuc.com>
Hi Tommy Grav, you recently wrote in moray.win:
Could you zip the TGA and send it to me via email (lut### [at] stmuccom).
I'm not sure why this is happening. Is the bright part of the height
field not elevated in Moray's preview?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 17 Mar 2000 05:32:19
Message: <38D209B8.68A0313@astro.uio.no>
I'll send you the tga-file sometime this weekend. The problem seems to be that Moray
interpets the heightfield inversely from what pov-ray does. Use of the waterlevel
function
confirmes this as it is the lowest parts of the heightfield (from povrays poit of
view) that
are left when I raise the wateerlevel. And yes, I'm currently trying out the preview
of Moray.
Great program by the way (ten thumbs up :-)
> - Lutz
Tommy Grav
