it's great new stuff in this release, but I don't have access to
material libraries anylonger, worked fine in the beta versions. The path
in the configuration is set. Does anybody have an idea what there might
be wrong?
Thanks
Rainer
Hi Rainer Ludwig, you recently wrote in moray.win:
> I don't have access to material libraries anylonger...
Hmm. Check the following registry key with RegEdit:
HKCU\Software\SoftTronics\Moray For Windows\Config
There is a String variable called TextureLibraryPath. Make sure it
points to the right place.
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Hi Lutz Kretzschmar,
thank you for this hint. Now it works fine.
Lutz Kretzschmar schrieb:
> Hi Rainer Ludwig, you recently wrote in moray.win:>> > I don't have access to material libraries anylonger...> Hmm. Check the following registry key with RegEdit:>> HKCU\Software\SoftTronics\Moray For Windows\Config>> There is a String variable called TextureLibraryPath. Make sure it> points to the right place.>> - Lutz> email : lut### [at] stmuccom> Web : http://www.stmuc.com/moray
II*
