when i create a smoke gen object with the plug-in and manually scale
it. it gives the following error:
File:VecList.cpp at line 69
If i hit ignore it scales it right and every thing. Not sure if this
is a Moray 3.2 Beta bug or a SmokeGen plug-in bug.... please this is
very irritating.
I am using a Protec brand computer with a AMD K-6 II processor with a
Sis 530 vidcard with 57MB of ram and 8MB of shared Video ram.
Psychomek
Hi Psychomek,
I'll look into it.
Best Regards,
Keith
Psychomek wrote:
> > when i create a smoke gen object with the plug-in and manually scale> it. it gives the following error:> > File:VecList.cpp at line 69> > If i hit ignore it scales it right and every thing. Not sure if this> is a Moray 3.2 Beta bug or a SmokeGen plug-in bug.... please this is> very irritating.> > I am using a Protec brand computer with a AMD K-6 II processor with a> Sis 530 vidcard with 57MB of ram and 8MB of shared Video ram.> > Psychomek
http://users.zetnet.co.uk/keithh/index.htm
kei### [at] totalisecouk
kei### [at] zetnetcouk
Thanks
Keith Hull wrote:
> Hi Psychomek,>> I'll look into it.>> Best Regards,> Keith>> Psychomek wrote:> >> > when i create a smoke gen object with the plug-in and manually scale> > it. it gives the following error:> >> > File:VecList.cpp at line 69> >> > If i hit ignore it scales it right and every thing. Not sure if this> > is a Moray 3.2 Beta bug or a SmokeGen plug-in bug.... please this is> > very irritating.> >> > I am using a Protec brand computer with a AMD K-6 II processor with a> > Sis 530 vidcard with 57MB of ram and 8MB of shared Video ram.> >> > Psychomek>> --> ------------------------------------------> http://users.zetnet.co.uk/keithh/index.htm> ------------------------------------------> kei### [at] totalisecouk> kei### [at] zetnetcouk> ------------------------------------------
Hi Psychomek, you recently wrote in moray.win:
How are you doing this? When I create a SmokeGen object I have no
possibility of scaling anything.
- Lutz
email : lut### [at] stmuccom
Web : http://www.stmuc.com/moray
Lutz Kretzschmar wrote:
> Hi Psychomek, you recently wrote in moray.win:>> > when i create a smoke gen object with the plug-in and manually scale> > it. it gives the following error:> How are you doing this? When I create a SmokeGen object I have no> possibility of scaling anything.>> - Lutz> email : lut### [at] stmuccom> Web : http://www.stmuc.com/moray
Not sure how i did it... but it scales but with the error.
When i installed the smoke gen i put the plugin in the plugin directory for
moray and the inc files in the includes for povray and it scales.... but
can't render cause of some problem with the Smokegen.MRY so i can't give
you a sample
also see my post in Moray.binaries
Hi Psychomek/Lutz
Lutz you probably have the older version!
Scaling is in the modify tab but won't accomplish (sp) anything as you
can't scale the smoke object. You can only scale the Smoke Placeholder
(the cone shaped object). Neither can you rotate the Smoke but the
placeholder will rotate! As for Psychomeks error I can't reproduce it
To make the smoke bigger you will need to make the Max Final Size
bigger!
Keith
> > Hi Psychomek, you recently wrote in moray.win:> > > when i create a smoke gen object with the plug-in and manually scale> > it. it gives the following error:> How are you doing this? When I create a SmokeGen object I have no> possibility of scaling anything.> > - Lutz> email : lut### [at] stmuccom> Web : http://www.stmuc.com/moray
