POV-Ray : Newsgroups : moray.win : DXF out Server Time
28 Jul 2024 18:19:25 EDT (-0400)
  DXF out (Message 1 to 3 of 3)
Subject: DXF out
Date: 20 Jan 2000 03:27:08
Message: <3886C644.C43E62DD@tijd.com>
Hey guys,
Is it possible to export an object to DXF in Moray ? If not ... is it
hard to make an exporter ?
Thanks
Subject: Re: DXF out
Date: 20 Jan 2000 08:03:42
Message: <3887082E.5C65AEE3@mninter.net>
Hey, we seem to be in the same fix, actually. I'm trying to write a RIB
exporter. Lutz said that if he had time, he might help write a general
export plugin, where you just fill in the way each shape should be
exported. But that probably won't be for a month or more, so you might
try to figure out the SDK.
Jos Bellefroid wrote:
> Hey guys,
> Thanks
You Know You've Been Raytracing Too Long When:
 You see the movie credits going by instead of seeing Lenses by Panaflex
    it always seems to say Lens Effects by Chris Colefax.
Produced by Alex Magidow's Sig File Randomizer(YKYBRTTL jokes courtesy of
c.g.r.raytracing)
Date: 20 Jan 2000 14:32:42
Message: <388760d3.19856582@194.174.214.110>
Hi Jos Bellefroid, you recently wrote in moray.win:
Define "possible"<g>.
I guess it's possible, but it is very difficult because Moray is a CSG
modeller and not a triangle modeller, whereas DXF is a triangle-based
format. Converting CSG to triangles is a very difficult task.
> If not ... is it hard to make an exporter ?
If you mean is it generally hard to make an export plugin then it's
not hard to make one. If you mean is it hard to make an DXF export
plugin, see above.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
