Running the Animation Plugin with POV (Message 1 to 3 of 3)
Subject: Running the Animation Plugin with POV
Date: 18 Jan 2000 14:45:29
Message: <3884C2EB.4EADF613@emc-inc.com>
I installed the animation plugin, and POV does provide a message that
says that the GUI Extension is being loaded.
However, when I select the Animation menu item, POV does nothing & the
rendering happens in the 'Polyray' window.
I am using MegaPOV for Windows with Moray 3.2.
Any ideas???
Thanks,
Tony Vigil
Subject: Re: Running the Animation Plugin with POV
Date: 18 Jan 2000 15:11:21
Message: <3884c8e9@news.povray.org>
Try looking under render options and setting it for pov. then I think you
will need to edit the master pov ini file to animate with pov
Tony Vigil <tvi### [at] emc-inccom> wrote in message
news:3884C2EB.4EADF613@emc-inc.com...
> I installed the animation plugin, and POV does provide a message that> says that the GUI Extension is being loaded.>> However, when I select the Animation menu item, POV does nothing & the> rendering happens in the 'Polyray' window.>> I am using MegaPOV for Windows with Moray 3.2.>> Any ideas???>> Thanks,>> Tony Vigil>
Date: 18 Jan 2000 15:30:37
Message: <3884CD7D.B7F96D06@emc-inc.com>
Funny, I didn't even notice the POVRAY option in the render settings.
Thanks for your quick & simple response!
Steven Durham wrote:
> Try looking under render options and setting it for pov. then I think you> will need to edit the master pov ini file to animate with pov
