POV-Ray : Newsgroups : moray.win : HeightFields Server Time
11 Nov 2026 22:36:56 EST (-0500)
  HeightFields (Message 1 to 12 of 12)
Subject: HeightFields
Date: 1 Nov 1999 02:17:54
Message: <381d3ea2@news.povray.org>
Is there anyone out there to tell me why when I use a .tga file to produce a
heightfield, I see a flat plane instead of mountains and valleys?
Thanks in advance
Margaritis Paktitis
Subject: Re: HeightFields
Date: 1 Nov 1999 05:56:04
Message: <381d71c4@news.povray.org>
I always use tga files, are you sure povray and moray can find the file, and
that the tga really is a tga? -
SWIFT ETEBA <swi### [at] etebagr> wrote in message
news:381d3ea2@news.povray.org...
a
> Thanks in advance
> Margaritis Paktitis
Date: 1 Nov 1999 06:11:48
Message: <381D74ED.D0A8518F@pacbell.net>
> Rick
  If it were an improper file format of if Pov were unable to find
it an error would be returned to that effect and the render would stop.
Ken Tyler -  1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 2 Nov 1999 03:42:35
Message: <381ea39a.4013040@194.174.214.110>
Hi SWIFT ETEBA, you recently wrote in moray.win:
Only thing I can think of is that the waterlevel is too high, the
heightfield is scaled too small in Z, the TGA file has very little
contrast.
Does Moray show the heightfield as flat, too?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 2 Nov 1999 23:56:54
Message: <381fc096@news.povray.org>
Ï Lutz Kretzschmar <lut### [at] stmuccom> Ýãñáøå óôï ìÞíõìá óõæÞôçóçò:
381### [at] 194174214110...
produce a
> contrast.
> - Lutz
Yes! Moray shows the heightfield flat.
I will try for a different value in Z.
Thanks.
Date: 4 Nov 1999 08:35:07
Message: <38218BC9.BD1D5812@cyberhighway.net>
Did you click on read?
> Thanks in advance
> Margaritis Paktitis
Date: 5 Nov 1999 02:53:23
Message: <38228cf3@news.povray.org>
Yes! I clicked on READ.
Yes! I altered the Z factor.
Nothing! Always flat
Thanks for your reply.
Ï Psychomek Ýãñáøå óôï ìÞíõìá <38218BC9.BD1D5812@cyberhighway.net>...
produce a
>> Thanks in advance
>> Margaritis Paktitis
Date: 5 Nov 1999 03:12:40
Message: <382290AC.BBA03AF9@pacbell.net>
If you will send me the tga file I will examine it for you and let you know
if it contains bad data or no data at all.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 5 Nov 1999 07:32:15
Message: <3822ce4f@news.povray.org>
know
isnt that what i suggested right at the start of the thread? we seem to have
come full circle..
Que the sound track from lion king.....
Date: 5 Nov 1999 13:37:47
Message: <382323fb@news.povray.org>
This is the tga file I am trying to use.
Thanks again and please be gentle with me if all this is caused only because
I am a newbie
Ï Ken <tyl### [at] pacbellnet> Ýãñáøå óôï ìÞíõìá óõæÞôçóçò:
382290AC.BBA03AF9@pacbell.net...
know
Download 'takis.tga.tar' (193 KB)
Date: 5 Nov 1999 18:09:28
Message: <382363CD.2A3A9F40@pacbell.net>
> I am a newbie
The tga file contains ho height data because it has only one color - black.
With HF's you need to understand how they work when you are designing the
image to make terrain with it. Black = no height and white = maximum height.
For example if you go into a paint program and put white lettering on a
black background then render it the white lettering will become a raised
text object. If you put black lettering on a white background you will
end up with a raised background when you render it with the letters sunken
into the surface.
There is a great discussion on height fields at this site that you should
read for detailed info on the subject:
http://www.daylongraphics.com/products/leveller/hf.htm
P.S. Please cancel your last post - the one with the attached image.
This is a non binaries group and images should not be posted here.
Thanks,
Date: 8 Nov 1999 10:18:11
Message: <3826e9b3@news.povray.org>
ok, that tga you posted is fine - however being totally black it will only
create a perfect flat plane.
open it up in psp, put some big white splodges on it, then try again.
black = 0 height
white = max height
Takis Paktitis <mpa### [at] groovygr> wrote in message
news:382323fb@news.povray.org...
because
> I am a newbie
> know
> > http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
