POV-Ray : Newsgroups : moray.win : Moray 3.1: can't adjust filter or transp. Server Time
28 Sep 2024 01:19:54 EDT (-0400)
  Moray 3.1: can't adjust filter or transp. (Message 1 to 3 of 3)
Subject: Moray 3.1: can't adjust filter or transp.
Date: 15 Oct 1999 09:50:09
Message: <38073185.949701E4@accn.org>
I have Moray 3.1 and POVRay 3.1g. In Moray, when I create a standard
texture, pigment, then solid color, the sliders for filter and
transparency are greyed out and I can't make my glass texture. Same
thing if I create a new material. Also, the Filter and Transparency are
greyed out on all my other textures I made. I have the unregistered
shareware version. Is this a limit of the shareware version? I thought I
could adjust F and T before in 3.1.
See my POV page. It has renderers and modellers and utils for windows,
OS2, unix. It is one of the largest collections of raytracing programs
on the net. My links concentrate on POV Ray and Windows programs. I also
have a list of POV objects sorted by object name.
http://www.geocities.com/~csroberts/Raytrace.htm
Subject: Re: Moray 3.1: can't adjust filter or transp.
Date: 15 Oct 1999 10:50:08
Message: <38073eaa.26700863@194.174.214.110>
Hi Chuck Roberts, you recently wrote in moray.win:
> .... if I create a new material. Also, the Filter and Transparency are
No, this is actually a bug that appears when the color dialog is used
to adjust a ambient or reflection color attached to a finish.
If you quit Moray and restart it the sliders will work again (until
you edit either of the abovementioned nodes.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 15 Oct 1999 13:57:43
Message: <38076B8C.4E15F9A9@accn.org>
Aha! Which I was doing.
Thank you.
http://www.geocities.com/Heartland/Plains/3959/Raytrace.htm
