On Fri, 15 Oct 1999 00:56:35 +0100, "David Sproson"
<spr### [at] green-vegetablefreeservecouk> wrote:
>Two things that i'm stuck on:
>1) Is it possible to apply decals to a texture in moray
>2) can you make spotlights visible?
These questions aren't specific to Moray. Consult the POV-Ray
documentation on image maps and media. You might also post novice questions
in the povray.newuser group, after first reading the official documentation
to see if your answers can be found there. Once you learn about image maps
you should have few problems using this feature in Moray. Media might be a
little trickier for the novice but a question posted in povray.newuser will
probably get a reply or two.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
