Thank you, Keith, that you put the roads into your plugin... but
unfortunately I still can't see them.
This is 'cause at startup Moray displays the following error message:
<errormsg> The plugin 'CityMFC.dll' could not be loaded. Make sure
that any other DLLs the plugin requires are present. Contact the
author of the plugin if you're not sure what the problem could be.
</errormsg>
So what is the problem? Did anyone else experience this too? Or does
the plugin really require some DLLs in the newest version? May I
believe Moray?
Thanks for answering
Florian Fischer
Hi Florian,
I'm not aware of any other dll that you may need unless I left it in
debug mode? However I've did find another bug last night (I didn't
calculate the number of edges and vectors correctly), which I've fixed
and uploaded.
Hopefully this should fix any problems:-)
Best Regards,
Keith
> </errormsg>
> believe Moray?
> Florian Fischer
Hi all
The city plugin doesn't work, even the last version. Same message than
Florian
Keith Hull a écrit:
> Hi Florian,
> and uploaded.
> Best Regards,
> Keith
> > </errormsg>
> > believe Moray?
> > Florian Fischer
LABORDE Christophe
thats funny, it works for me.
Steven
Christophe Laborde <lab### [at] club-internet fr> wrote in message
news:37D74BB4.71C7DF59@club-internet.fr...
> Hi all
> Florian
> Keith Hull a écrit:
> > Hi Florian,
> > and uploaded.
> > Best Regards,
> > Keith
> > > </errormsg>
> > > believe Moray?
> > > Florian Fischer
> LABORDE Christophe
Hi Steven,
Have you got MS VC installed?
Keith
> Steven
> > Hi all
> > Florian
> > Keith Hull a écrit:
> > > Hi Florian,
> > > and uploaded.
> > > Best Regards,
> > > Keith
> > > > </errormsg>
> > > > believe Moray?
> > > > Florian Fischer
> > LABORDE Christophe
I don't know, what is MS VC? I just downloaded the plugin and installed it
by the directions included and it works just fine for me. I posted an image
using only the city plugin and the galaxyplugin on moray binaries. thanx for
the great plugins keith
Keith Hull <kei### [at] totalise co uk> wrote in message
news:37D8017B.284294E3@totalise.co.uk...
> Hi Steven,
> Keith
> > Steven
> > > Hi all
> > > Florian
> > > Keith Hull a écrit:
> > > > Hi Florian,
fixed
> > > > and uploaded.
> > > > Best Regards,
> > > > Keith
message:
> > > > > </errormsg>
does
> > > > > believe Moray?
> > > > > Florian Fischer
> > > LABORDE Christophe
It works for me, and I have VC4 installed. Perhaps Steven has the DLLs
installed from another program?
-Ian
> Hi Steven,
> Keith
> > Steven
> > > Hi all
> > > Florian
> > > Keith Hull a écrit:
> > > > Hi Florian,
fixed
> > > > and uploaded.
> > > > Best Regards,
> > > > Keith
message:
> > > > > </errormsg>
does
> > > > > believe Moray?
> > > > > Florian Fischer
> > > LABORDE Christophe
MSVC = Microsoft Visual C++
-Ian
Steven Durham <ste### [at] earthlink net> wrote in message
news:37d80c17@news.povray.org...
for
> > Hi Steven,
> > Keith
*snip snip*
Well it' working fine for me as well and i'm pretty sure that i don't
have ms vc installed. But i do run a watcom 11 on my system, so thats
probably why it's working.
I remember a moray version, where some dll's were missing. I think this
package did it for me before installing my watcom. And if i remember
right, in the first version of Alexander Enzmann's plugin also some
dll's were missing.
Maybe he knows, which ones.
Not very much of a help, i'm afraid but maybe a hint.
Arne Kleinophorst
Hi All,
I don't know why the PlugIn is not working (using QuickView - the dll needs
the following dlls MFC42.dll MSVCRT.dll USER32.dll and KERNEL32.dll these
should all be available in the Win98 system directory). None of the dlls
are debug versions, which means that the correct version has been uploaded
to my website.
Can you all right click on the dll and use QuickView to look at the dlls
needed?
TIA,
Keith
> dll's were missing.
> Arne Kleinophorst
> dll needs the following dlls MFC42.dll MSVCRT.dll USER32.dll and
> KERNEL32.dll these should all be available in the Win98 system
> directory).
Well, good idea to use QuickView. I did this too and I see that you're
importing the following dlls:
MFC42D.dll MSVCRTD.dll KERNEL32.DLL USER32.DLL
so probably I'm not having the first and the second. They are debug
versions, aren't they?
But I'll look for the new version. You might have solved the problem.
Florian Fischer
Hi Florian,
Yep, the d after MFC42 and MSVCRT gives it away!
Hopefully the new version should be OK!
Best Regards,
keith
> Hi,
> > directory).
> Florian Fischer
Hi Keith,
> Hi Florian,
If you're referring to the version of 8/9/99: same problem in there.
I've tried it.
Bye
Florian
Just downloaded and tried the CityMFC.dll dated 9/7/99 (~80kb) and it failed
to load during the Moray startup. Yes, I am using MSVC V6 SP3 on my machine.
Your galaxy plugin works just fine, however.
..larry
> Hi Steven,
Hi There,
I think I've found the fault - please try again, the new version should be the
release version and it should not have any optimizations.
Best of Luck ;-)
Keith
> ..larry
> > Hi Steven,
Keith,
As you suggested, just downloaded the 9/10/99 version. Loads fine with
Moray - only had a few minutes with it and it seemed to behave nicely. I'll
experiment more with this plugin later, but looks good so far. Much
appreciated. While I've programmed over the years in C and C++, I'm
relatively new to Windows MSVC so I can appreciate the effort that one puts
into tracking down such a problem. Thanks again.
..larry
news:37DE8B92.6B003ADC@totalise.co.uk...
> Hi There,
the
> Best of Luck ;-)
> Keith
failed
machine.
