POV-Ray : Newsgroups : moray.win : importing texture definitions Server Time
11 Nov 2026 23:02:55 EST (-0500)
  importing texture definitions (Message 1 to 11 of 11)
Subject: importing texture definitions
Date: 4 May 1999 11:47:39
Message: <372f088b.0@news.povray.org>
Is there a simple way in Moray to import a POV inc file of texture
definitions??  I have an include file with several HUNDRED texture
definitions that I want to import for use with Moray.
Calin
http://www.calin.com
calin at calin dot com
Subject: Re: importing texture definitions
Date: 4 May 1999 13:01:01
Message: <37301950.9145550@194.174.214.110>
Hi ZuluNiner, you recently wrote in moray.win:
> definitions??
Simple? No, sorry. Actually there isn't any way, really.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 4 May 1999 13:13:17
Message: <372f1c9d.0@news.povray.org>
There exists somewhere (ask uncle ken) a povtomdl.exe utility (works with
POV3.0 definitions only)
Philippe
ZuluNiner a écrit dans le message <372f088b.0@news.povray.org>...
>Calin
Date: 4 May 1999 13:22:41
Message: <372f1ed1.0@news.povray.org>
I don't supposed you'd consider that as a future feature??
or possibly an external tool to convert texture definitions from POV inc to
library files??  Or even simply the ability to ADD a texture to an existing
library (and add new libraries.)
ZuluNiner
(aka Calin/Runesinger)
ZuluNiner at fuckyou dot co dot uk
Lutz Kretzschmar <lut### [at] stmuccom> wrote in message
news:373### [at] 194174214110...
> > definitions??
> - Lutz
Date: 4 May 1999 18:13:54
Message: <372f6312.0@news.povray.org>
Ph Gibone wrote in message <372f1c9d.0@news.povray.org>...
I think it is POV 2.0 ony, and the "somewhere" is Thomas Baier's site if I
am not mistaken (now hosted on the stmuc server...)
Johannes.
Date: 4 May 1999 18:34:40
Message: <372F67AA.33E5A969@mninter.net>
If you know how to do POV-Code(Or, if you are even lazier, use the same
names), just use the .inc file to texture each object. If you don't want
to do much work, just have it replace whatever texture name you gave it
in moray with the texture name you want to use.
> Calin
Given a lever long enough, one can move the world with little force
      MJ Engh
Date: 5 May 1999 02:35:18
Message: <372fd896.0@news.povray.org>
I didn't check, but I know that I have imported a lot of texture in Moray
with this program!
Anyone interested by the MTX files ?
You're not mistaken
Philippe
Date: 5 May 1999 09:25:00
Message: <3730381b.19213337@194.174.214.110>
Probably not. I don't have the time to write a POV-Ray parser from
scratch (which is what I'd have to do). However, this would be a
perfect task for the Plugin SDK.
I'm not sure what you mean by Library. But if you mean Moray Texture
Libraries (i.e. *.MTX files), then you *can* add to them and create
new ones, etc. We are also working on better texture library
management for the next version of Moray.
- Lutz
Date: 5 May 1999 11:12:29
Message: <37305148.4CA5EDD9@pacbell.net>
> - Lutz
Lutz,
  Have you by any chance seen the C++ programming library called ParPov ?
  A brief discription from the home page of the program source.
   ParPov is a free (GNU), object-oriented library written in C++ for
parsing Scene Files of the Persistence of Vision Ray-Tracer (POV-Ray).
It will read a scene written in version 1-3 syntax and creates a structure
of C++-Objects, representing all details of the original description. You
can query those objects and use the information for conversion to other
formats or for many other uses. Pov2Rib is also a freely available progam,
which allows you to convert scene files from POV-Ray to a RenderMan Interface
Bytestream (RIB). The tool is the first application of libParPov.
This is the first work I have seen that actually parses Pov files and
converts it to usable data. More information can be found at the link
below.
http://www9.informatik.uni-erlangen.de/~cnvogelg/pov2rib/index.html
Ken Tyler
mailto://tylereng@pacbell.net
Date: 6 May 1999 09:38:38
Message: <37318cdd.12045340@194.174.214.110>
Hi Ken, you recently wrote in moray.win:
I've heard of it.
[Later]
I just checked out the website. Although technically it may be
feasable, the fact that it is under the GNU license means I have to
release source code of any programs I incorporate it into, right?
- Lutz
Date: 6 May 1999 19:09:24
Message: <37321314.0@news.povray.org>
No.  Under the GNU license, your modified version of the original GNU source
has to be public, but your own code can be licensed under a different
licensing model.
In other words, you'll have to provide a public version of how you "hook"
the GNU code into Moray, but you won't have to release any of the
proprietary Moray code.
The simplest solution would be to do it as an import plugin.  That way the
only thing questionable about the release status is the Moray plugin SDK
(which is already public) and the ParPov code, which is also public.
ZuluNiner
news:37318cdd.12045340@194.174.214.110...
> I've heard of it.
> [Later]
> - Lutz
