POV-Ray : Newsgroups : moray.win : Saving files... Server Time
28 Sep 2024 11:18:49 EDT (-0400)
  Saving files... (Message 1 to 8 of 8)
Subject: Saving files...
Date: 27 Mar 1999 14:54:12
Message: <36FD28D5.1149@flash.net>
Ok, if povray renders the pic, it saves it to three different files.  A
.pov, .bmp, and another one. There isn't ANYWAY to get the Moray
pictures on teh .jpg file type?
Subject: Re: Saving files...
Date: 27 Mar 1999 15:07:35
Message: <36FD3987.BA8FADC9@pacbell.net>
  Moray is only showing you the preview image being fed from Pov-Ray.
Moray has no interal ability to produce any picture type except the
modeling environment. The output from Pov does not have a .jpg option
so you will have to take the better quality .bmp file that is produced
and convert it to the inferior quality .jpg format with a conversion
utility, paint program, or image manipulation program. The three main
types of image output that Pov uses are .tga, .bmp, and .png. It will
read in all three plus .gif files. Sorry but there is no support for
.jpg image files nor is there any plans to add it in the future that
I am aware of.
So in answer to your question yes there are three files .mdl, .pov, .bmp.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 27 Mar 1999 16:36:15
Message: <36fd4f4f.0@news.povray.org>
> Ken Tyler
Sorry Ken, your not wrong often, but this time you are. There are 4 files
i guess hell just froze over!  :-)
Date: 27 Mar 1999 16:45:33
Message: <36FD507D.5B8F0CCF@pacbell.net>
> > Ken Tyler
> .mdl,.pov,.inc,.bmp (or.tga, or .png)
Brrr... it's cold down here.
Ken Tyler
Date: 27 Mar 1999 20:46:10
Message: <36FD7B46.1FF8@flash.net>
Ken's not wrong.  I was talking about PovRay. NOT moray.  Better start
Date: 27 Mar 1999 21:37:02
Message: <36fd95ce.0@news.povray.org>
Crazyfish <opi### [at] flashnet> wrote in message news:36F### [at] flashnet...
.mdl files are generated by Moray ONLY, not povray. POVray only creates a
.bmp (.png or .tga) file. YOU create the .pov file, POVray makes the graphic
file.
Date: 29 Mar 1999 06:37:35
Message: <36ff65ff.0@news.povray.org>
Crazyfish,
I think the bit you might be missing is that to make a JPEG file, you need
something other than just Moray/Povray. For example PaintShop Pro(PSP).
The procedure is basically as follows. Open the BMP file that POVRay makes
in PSP (File/Open), then choose File/Save and in the Save As box that appear
click on the Save As Type box and pick JPG, then click Save. This will
create a JPEG file in the samo directory. You can then post this or do
whatever. This procedure is the same for most Paint type programs, others
are Photoshop, Picture Publisher, Painter, ...  There are also DOS utilities
that will do the conversion for you, but they tend to be a bit trickier to
use it you are a relatively new computer user.
Hope this helps.
Gordon
<gbe### [at] birdcameroncomlau>
PS Incidently, you really should read the manuals. Even if it doesn't make a
lot of sense, you will pick up something, then try to use your new
knowledge, then read it again, .............
That is how we all learn POV.
Crazyfish wrote in message <36F### [at] flashnet>...
Subject: Re: Saving files... GORDON
Date: 31 Mar 1999 17:40:03
Message: <37029599.316D@flash.net>
Heh.  New computer user? No.  Have you noticed that that msg was posted
about two weeks ago?  I've learned a great deal of knowlege about
Moray.  See my site crazyfish.8m.com and see the proof.
