POV-Ray : Newsgroups : moray.win : Re: Need a window.. Server Time
18 Jan 2026 06:23:29 EST (-0500)
  Re: Need a window.. (Message 1 to 2 of 2)
Subject: Re: Need a window..
Date: 20 Mar 1999 21:40:21
Message: <36F45BE7.40DED940@mninter.net>
mdm### [at] postoffice2bellatlanticnet wrote:
> Ok, I kind of fixed it... used a Cube with a thickness of 0.5 instead of a
> plane...
What might the other part of teh problem be?
> I had assumed that because Moray allows you to choose the height/width
> thickness of a plane, it would mean it'd be limited like a box or
> something.  Instead, the plane is automatically rendered infinite.
> Michael
Only I can prevent narcissism!
Date: 20 Mar 1999 21:43:20
Message: <36F45C9B.1CA86961@mninter.net>
> plane...
Oh, yeah. Planes are alway infinite- morays sizing only changed the wireframe
representation. This is helpful in cases where your scale is very high. This
is also true of Point Lights, which are only a point- the size is only a
factor of the wireframe, not of the light itself. Again, this is to increase
the visibility of the object during the modeling process- it has no bearing on
the rendering process.
> Michael
