How do I enable radiosity in Moray? It already export a whole bunch of
radiosity settings, but I am not quite sure it has been turned on(the
radiosity settings are the standard ones. I haven't touched them)
Only I can prevent narcissism!
You enable radiosity in the render options screen. You can adjust the
radiosity settings by going to
scene--> settings--> radiosity tab. I hope that helps out.
Kyle
Alex Magidow wrote:
> > How do I enable radiosity in Moray? It already export a whole bunch of> radiosity settings, but I am not quite sure it has been turned on(the> radiosity settings are the standard ones. I haven't touched them)> > --> Only I can prevent narcissism!
Kyle wrote in message <36DC3BC0.2C89F702@geocities.com>...
>You enable radiosity in the render options screen. You can adjust the>radiosity settings by going to>scene--> settings--> radiosity tab. I hope that helps out.> Kyle>>
Or, If you are rendering from within pov, use the appropriate command line
switch in your .ini file. +QR, if I recall correctly.
