POV-Ray : Newsgroups : moray.win : NK Lens Flare Server Time
28 Sep 2024 13:20:20 EDT (-0400)
  NK Lens Flare (Message 1 to 2 of 2)
Subject: NK Lens Flare
Date: 11 Feb 1999 17:35:22
Message: <36C35B5B.2630828D@tecmasters.com>
I would apprecitate anyones response to the following:
    How do I make lens flares work in Moray 3.1?  I've read the text
files that were included in the plugin's directory when I downloaded
Moray and as far I know I've followed the instructions accurately.  I've
set/declared  lightsource and cameras. Still no luck. Any advise or
pointers are greatly appreciated.
E-mail: cst### [at] sirinetnet
Subject: Re: NK Lens Flare
Date: 12 Feb 1999 09:46:20
Message: <36C43ECE.7C447FF1@Kopp.com>
If you're using the flare INC file through Moray, you don't need to do any
#declaring or #including yourself.  Moray takes care of all of that.  Just
make a light source, a camera, and a lens-flare object.  Then, select the
lens-flare object and choose your light & camera objects.  Finally, choose
your favorite flare type & brightness/size levels.  Make sure you can see
the light source in the camera's view and press render.  It should work.
If not.... check POV's message window for any 'file not found' errors.
-Nathan
