POV-Ray : Newsgroups : moray.win : Spray plugin problems. Server Time
11 Nov 2026 23:39:19 EST (-0500)
  Spray plugin problems. (Message 1 to 8 of 8)
Subject: Spray plugin problems.
Date: 8 Feb 1999 13:15:35
Message: <36BF2971.4A1A45EB@mninter.net>
I have been trying to use the spray plugin, but whenever I try to click
on the "use blob component" check box, it gives me an invalid page
fault, and moray crashes. Anyone know why?
Only I can prevent narcissism!
Subject: Re: Spray plugin problems.
Date: 8 Feb 1999 13:18:26
Message: <36BF2A11.CE908CD2@mninter.net>
In fact, when I try to use ANY of the checkboxes, it messes up.
Subject: False alarm!
Date: 8 Feb 1999 13:45:59
Message: <36BF3091.61BFC2E1@mninter.net>
Sorry. It just turns out that my copy of the DLL somehow got corrupted.
Damn Windows 95.
Subject: Re: False alarm!
Date: 8 Feb 1999 17:28:25
Message: <36BF6552.41E8E317@istar.ca>
> Damn Windows 95.
Well, I have the identical problem (as do several others, I believe). How did
you fix it (if you did)?
Also, the default values yelid a blank scene, probably for the same reason.
Date: 8 Feb 1999 20:10:23
Message: <36BF8A9B.267405C6@mninter.net>
Well, actually, I just reinstalled the old v.6b( the unupdated one, around 70k.
The newer one, v.7, is about 50k.), which had worked fine before, and still works
now. It works perfectly.
Simon de Vet wrote:
> > Damn Windows 95.
Date: 9 Feb 1999 17:48:28
Message: <36C0BBA0.CF52E2D9@istar.ca>
Ok.. mine have never worked, and version.
Subject: Spray Plugin Problems
Date: 10 Feb 1999 07:27:36
Message: <36C179A5.E1FC2E78@mitre.org>
By any chance are the people having problems using Visual Studio 6?
[Most notably C++ 6] - The spray plugin loaded just fine for me up until
I upgraded from VC5 to VC6.  The symptom I get is an access violation in
the CString class during the load operation.
You could also get this sort of problem if you have installed programs
built with VC6 - there is a new runtime MSVCRT.DLL/MSVCRTD.DLL (as well
as the standard MFC42.DLL) that purports to give improved heap
management.  If these were installed you could have problems.  On the MS
web site it notes that these can be incompatible with code built in
earlier versions of VC (they say it's not a bug...).
Service Pack 2 is supposed to fix these problems.  I installed it and
still have the same error.
Xander
Subject: Re: Spray Plugin Problems
Date: 12 Feb 1999 01:56:18
Message: <36c3d092.0@news.povray.org>
Alexander Enzmann wrote in message <36C179A5.E1FC2E78@mitre.org>...
|Simon de Vet wrote:
|> Alex Magidow wrote:
<snip>
|Xander
I have the same problem in Win98, which is *supposed* to supercede SP2
(Win95b). Same fix worked, going back to v.6.
Lue Ebra
lue### [at] dalnetsuxmuh-nutzorg
www.electro-net.com/~lueebra
"If you're the instant gratification type, you've definitely chosen the
wrong hobby" -comment to my wife on IRC while she was waiting for a scene to
finish rendering
