POV-Ray : Newsgroups : moray.win : NOTE: POV-Ray hanging problem Server Time
11 Nov 2026 23:51:15 EST (-0500)
  NOTE: POV-Ray hanging problem (Message 1 to 1 of 1)
Subject: NOTE: POV-Ray hanging problem
Date: 10 Jan 1999 13:26:57
Message: <3698f0c7.7958213@194.174.214.110>
Dear Moray Users,
if any of you are getting the 'POV-Ray hangs when a faulty render is
started' problem, and Moray does not offer you a dialog to change
POV-Ray settings on startup, I would like to ask you to do the
following:
- Start RegEdit (Start menu, Run, RegEdit)
- Open HKEY_LOCAL_MACHINE\SOFTWARE\POV-Ray in the left pane.
  Highlight the POV-Ray entry in the left pane.
- Select Registry|Export Registry file from the menu.
- Type in a name for the file, preferably 'myname.txt'.
- Make sure the 'Export range' is set to 'Selected branch'
  with the HKEY_LOCAL_MACHINE\SOFTWARE\POV-Ray in the edit box.
- Click Save.
- Close RegEdit.
- Send me the file per email.
Since Moray contains code to check POV-Ray for the correct settings
and should offer to change them, this will allow me to check why it
isn't doing this.
Thanks,
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
