POV-Ray : Newsgroups : moray.win : Loading Enzmanns Polyray-plugin Server Time
12 Nov 2026 00:03:12 EST (-0500)
  Loading Enzmanns Polyray-plugin (Message 1 to 11 of 11)
Subject: Loading Enzmanns Polyray-plugin
Date: 7 Jan 1999 08:55:58
Message: <3694BC9F.740A@innet.be>
Can someone help me ... I cann't load the polyray-plugin into MorayWin
(although I followed the steps if the readme.txt).
Thanks in advance you great guys
Ann
Subject: Re: Loading Enzmanns Polyray-plugin
Date: 7 Jan 1999 12:16:06
Message: <3694ebd6.0@news.povray.org>
What goes wrong?
Ann Vervoe wrote in message <369### [at] innetbe>...
>Ann
Date: 8 Jan 1999 00:32:05
Message: <36959962.B2A04EC4@europa.com>
Where is the plugin available at?
> Ann
Of all, the worst humiliation women bring upon us
is the inferiority of our rivals.
Date: 8 Jan 1999 03:23:07
Message: <3695bf7d.4005910@194.174.214.110>
Hi Ann Vervoe, you recently wrote in moray.win:
Does it appear in the View|Loaded Plugins dialog (note that it can be
scrolled)?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 8 Jan 1999 03:23:08
Message: <3695bf9b.4035833@194.174.214.110>
Hi Dearmad, you recently wrote in moray.win:
Our website on the Downloads|Plugins page.
- Lutz
Date: 8 Jan 1999 04:14:39
Message: <3695CC33.68D@innet.be>
> scrolled)?
> - Lutz
No, it doestn't, although I can see it loading in at startup. I tried it
yesterday on a win95 system and it worked okay, but here on a NT4 sp3
system it won't work ... strange. Thanks for your quick reply ... I'm
saving my last dime so I can register this marvelous modeler.
Ann
Date: 9 Jan 1999 07:32:27
Message: <36974d31.1659095@194.174.214.110>
Huh? So you 're saying that you can see RenderMoray.DLL being listed
in the splash screen during startup, but not in the Loaded Plugins
dialog. Hmmm. It's weird because I've had one or two other reports
that the plugin isn't being loaded, but I have had no problems (I work
under NT4 SP3).
- Lutz
Date: 9 Jan 1999 12:48:54
Message: <36979686.0@news.povray.org>
I have had that same problem.  Any clues as to why?
Lutz Kretzschmar wrote in message <369### [at] 194174214110>...
>under NT4 SP3).
>- Lutz
Date: 9 Jan 1999 13:46:59
Message: <3697A3AF.39B9C47@geocities.com>
> Ann
I like I'm having the same problem as everyone else with the plugin.  I
followed the intructions for installing the plugin to the letter from the
readme file.  I can see the name loading on the splash screen, but within
moray I can't find it anywhere.  It's not under view-> loaded plugins, and
under Plugins it just says [empty].  The lens flare and other plugins work
fine though.  I've tried changing my Path directory and copying the .dll's
to a bunch of different directories with no luck.  Any clues?
                    Kyle
Date: 10 Jan 1999 10:58:04
Message: <01be3cb2$0c475800$bef2903e@lightsaber>
> under NT4 SP3).
I got the same problem under Win 95 he lists it on the plash screen but
it's not under the loaded plugins and the additional menus do not appear :(
Date: 11 Jan 1999 07:28:13
Message: <01be3d5d$22b6a2c0$89d45381@aenzmann.mitre.org>
Ann Vervoe <Ver### [at] innetbe> wrote in article <369### [at] innetbe>...
> Ann
Sorry for the delay - been out of town for the last week.
If all the loading problems are occuring on NT systems, there is one thing
that -could- be the problem.  Check the capitalization of the two DLL's on
your system.  They should be: "RenderMoray.dll", and "Polyray2.dll".  I've
found that NT is much pickier about use of caps versus lower letters in
DLL's.
If Windows can't find the DLL, you should be seeing a message box that says
something like, "A required DLL, "Polyray2.dll" couldn't be located".  If
it's actually getting loaded by Moray, and then something goes wrong, I'll
have to work with Lutz to determine just what is going wrong.
I think Lutz asked for the first clues - Is it on the list of loaded
plugins?  Does an entry appear on the Import menu (Mesh)?
I only have Win '95 and '98 to test on, and it was working without a hitch
there...
I tried to make the installation as simple as I could.  There are two
libraries involved.  One is the actual plugin, "RenderMoray", and goes in
the Moray plugin directory.  The other is the actual renderer and can go
either somewhere in your PATH, or in Moray's main directory (where
MorayWin.exe resides).
Xander
