If I want to write a POV, how do I move it to Moray to change the model?
Sounds like you are trying to use Moray to read in a POV text file. If you
are,
Moray doesn't do that. I don't know of any modeller that reads in POV
files.
Debi Hodges wrote in message <368A5039.E72CE142@emrys.com>...
I want to be able to generate in Moray, render in POV and change in POV, then
go back to Moray to adjust. hmmm.
> are,
> files.
You can generate in Moray, render in POV and change in POV and then that's
it.
Debi Hodges wrote in message <368A5135.4ACCE5F4@emrys.com>...
then
you
>> are,
>> files.
Thanks =) I guess that's another reason to just use POV alone and not bother
with the GUI interface =)
> it.
> then
> you
> >> are,
> >> files.
Can we say plugin?
Well, unfortunately, I don't think that that will be possible, due to the unique
syntax that each person uses in POV-Ray.
> > are,
> > files.
"Only after the last tree has been cut down. Only after the last river has
been poisoned. Only after the last fish has been caught. Only then will you
find that money cannot be eaten."- Cree Indian Prophecy
Hi Debi Hodges, you recently wrote in moray.win:
What are you trying to change that you can't do inside Moray? Or are
you trying to use loops or macros in the POV script?
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
Debi Hodges heeft geschreven in bericht <368A5C47.20948870@emrys.com>...
bother
that's
>> it.
>> then
If
>> you
>> >> are,
>> >> files.
model?
I used pov2mdl to convert the X-Wing model which I found on "StarWars: the
POVRay Collection" into a mdl-file. Ofcourse I had to change the original
POV-file a bit to make it convertable, and after it was converted I still
had to place some objects manually, but it still was quite a help. (You can
find the results of this work on povray.binaries.images, look for subject
"more starwars")
ZK
can
>"more starwars")
Exist some program that realizes conversions to MDL from POV 3.0 or 3.1?
Occured that the model X-Wing of "StarWars :POVRAY Collection" and other,
do not can carry to MDL easily with pov2mdl.
Greetings :
Juan Carlos Márquez wrote in message <368d08c5.0@news.povray.org>...
Not at this time, in this universe, sorry.
Johannes.
There is only a POV 2.2 to mdl converter, and it only works with a subset,
and i have no idea where it lives on the net..
Johannes Hubert wrote in message <368dffdb.0@news.povray.org>...
>Johannes.
