I downloaded the newest compile of Moray 3.1 and there's still nothing
listed under the plugins section. Anyone else having this problem?
Joe
> Joe
Lens Flare is part of the Create Tab. If you are running less than
1024x768 resolution on your screen, you won't be able to see the Lens
Flare button. Place the mouse over a gray area and it will become a hand,
click and hold to drag the menu up to be able to see the Lens Flare.
Daniel Hargreaves
SD Graphics
ArchSymb for AutoCAD and IntelliCAD
http://home.att.net/~dkh007/archsymb
CADD Standards
http://home.att.net/~dkh007/caddstd
Thanks for your prompt response. However, the first place I looked was under
the create tab, and at the bottom there's a spot for plugins...and the spot
is blank. Any ideas?
Joe
> Daniel Hargreaves
> SD Graphics
> CADD Standards
> Joe
<SNIP>
Ok, check your Moray folder and see if the Plugins folder has anything in it.
From what I understand all you have to do is place the associated DLL plugin in
that folder and the next time you launch Moray it will load the plugin.
Daniel Hargreaves
SD Graphics
CADD Standards
Yuk. I already did that too. Have you run out of ideas yet, or do you feel like
running another one by me?
Thanks,
Joe
> <SNIP>
> Daniel Hargreaves
> SD Graphics
> CADD Standards
Hi Joe Prever, you recently wrote in moray.win:
Your terminology is a bit confusing. What is the 'plugin section'?
A plugin does not have to add menu items, so you may not even notice
(at first) that a plugin has been loaded.
To find out whether a plugin is loaded, check whether it is listed in
the dialog that pops up when you select View|Loaded Plugins.
If it isn't, then the plugin is not loaded. This could have two
reasons:
- The DLL isn't in the correct place.
- It's not a Moray Plugin.
The second option you can disregard for the standard plugins. The
first problem can be verified by going into the View|Configuration
dialog and the Advanced Tab. Check where the 'Directory to search for
Plugin DLLs' is pointing. Make sure the DLLs can be found there.
Let me know if it still isn't working.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
Hi Lutz,
Thanks for your response to my message. I used your suggestions regarding
the plugins, and I'm afraid they still won't work. Perhaps I should've
mentioned this before, but I had previously uninstalled Moray 3.1 manually
(the automatic uninstallation failed). Does that help?
Thanks again,
Joe
> reasons:
> - Lutz
Joe Prever wrote in message <36897065.EAE0FC80@turbont.net>...
>Hi Lutz,
I had something similar:
When I installed Moray 3.1 I still had Moray registry entries left from
previous Moray installations (among them the 3.1 beta), even though the
previous installations had already been deinstalled.
After installing 3.1 I didn't see the Plug-Ins in the Creation Tab.
However, because of the old registry entries I also had troubles with older
search paths spooking around and with a missing MorayPoly.inc and other
problems, so I had good reasons to re-install.
So this is what I did: I uninstalled Moray 3.1 again, then I went into the
registry by hand and deleted the Moray keys in
HKEY_LOCAL_MACHINE\Software\SoftTronics and
HKEY_CURRENT_USER\Software\SoftTronics. Then I installed 3.1 again, and
everything went fine, with the Plugins too.
Hope it helps,
Johannes.
"Won't work" as in? Are they listed in the View|Loaded Plugins dialog
or not?
- Lutz
Sorry about that -- I mean the plugins don't appear anywhere, not in the
View|Loaded Plugins dialog or anywhere.
Joe
And the path in the Plugin Path field of the Advanced Tab in the
View|Configuration dialog points to the directory where the plugins
are located? Absolutely sure?
- Lutz
*Absoutely* sure. But I think Johannes's idea is good I've followed his
instructions and am now re-downloading. I'll tell you how it goes.
Joe
Hooray! It worked. Thanks, Johannes and Lutz, for all your help. Lutz,
I'm quite impressed -- it's not everyone who would give personalized tech
support, and so quickly, even to an unregistered user.
Many thanks,
Joe Prever
Hmm. What did you actually do? Remove the registry keys and
re-install? I don't see why you couldn't get it to run.
- Lutz
Here's what I did: uninstalled Moray 3.1, went into regedit, and there
deleted the SoftTronics folder (under SOFTWARE, under
HKEY_LOCAL_MACHINE). Then I downloaded Moray 3.1 again (the latest
build) and reinstalled -- and now everything works great.
I'm no programmer so I can't offer any opinion on why I couldn't get it
to work before, but I hope this info helps.
Joe
Not exactly I run in 800x600 and I see the tab and the button
