poty wrote:
> how do you save the image that i just rendered from moray without having to
> export and rerender the file?
If the name of your model is "Mymodel.mdl" then after rendering, you will find
an image file "Mymodel.tga" in the folder Povray renders in. This is usually
the "Povscn" subfolder of the Moray installation folder. (Or the "Polyscn"
subfolder if you are using polyray). Simply copy that file to somewhere else...
Hope that helps,
Johannes.
