I am using the texture editor in Moray to create a simple checker
pattern with a solid color(Black) and a built-in texture (T_stone14).
After adding the solid color under the "checker pigments" box, how can I
add the T_stone14 texture to it ?
Thank you.
Subject: Re: help: texture editor
Date: 25 Feb 1998 12:54:55
Message: <34F45AEF.92E@osu.edu>
abc wrote:
> > Hi,> I am using the texture editor in Moray to create a simple checker> pattern with a solid color(Black) and a built-in texture (T_stone14).> After adding the solid color under the "checker pigments" box, how can I> add the T_stone14 texture to it ?> > Thank you.
I think you can just copy/paste it into a new layer. you have to use
layered texture a believe. don't rely on my statements 100% for i am a
new user of moray/povray
On Thu, 26 Feb 1998 01:01:34 +0800, abc <abc### [at] usthk> wrote:
>Hi,> I am using the texture editor in Moray to create a simple checker>pattern with a solid color(Black) and a built-in texture (T_stone14).>After adding the solid color under the "checker pigments" box, how can I>add the T_stone14 texture to it ?>>Thank you.>>
The trick is to start with the Create of a 'Block Pattern Texture'
Then you can add the solid black as the first pigment and either paste
the stone texture as the second one or Copy as Subtexture from the
library
Good Luck
George Hunt
http://ourworld.compuserve.com/homepages/lightsword
GHu### [at] aolcom
