For anyone having problems with the renderer plugin (even after checking
paths and directory locations, ...), please look and see if the following
DLL is on your system: MSVCP50.DLL.
I use the C++ Standard Template Library within the plugin, and the
implementation of some of the STL classes is inside that dll. It may not
be a standard thing installed in Windows systems (although it will be for
anyone that uses VC++).
Xander
Yep, That fixed it for me. I never would have guessed it. Thanks alot
Alexander.
Kyle
I have VC++ 6 installed and i do not have that dll anywhere!
Alexander Enzmann wrote in message
<01be43d6$870a15c0$89d45381@aenzmann.mitre.org>...
>Xander
Rick <kit### [at] dialpipexcom> wrote in article
<36a54fa6.0@news.povray.org>...
Hmmmm, I bet MS changed their runtime libraries again. Do they have
something like MSVCP60.DLL?
Lutz and I are both using VC++ 5. If you need a copy of that DLL, go to
http://pages.hotbot.com/arts/are/index.html - I put a zipped copy of it
there.
I never thought of this particular problem, because I assumed that STL was
just templates and didn't need any support routines (other than the
standard stuff in MSVCRT.DLL). Silly me.
Xander
Anyone want to post the req dll's for Moray STK?
I have dl'd that dll, and it works fine now, no probs, just carn't get the
spray pug working now!
<01be4474$476132c0$89d45381@aenzmann.mitre.org>...
>there.
>Xander
Rick wrote in message <36a648ca.0@news.povray.org>...
The Spray PlugIn was originally sent to Lutz as a debug release, I've now
sent him a release version which hopefully should cure everyones problems
Sorry!!
Best Regards,
Keith
>> go to http://pages.hotbot.com/arts/are/index.html - I put a zipped
>> copy of it there.
Hey, thanks, Xander! I'll bet that's all I need to get your plug-in to
load.
- Alan
"I will go up to the six-fingered man and say, 'Hello, my name is
Inigo Montoya. You killed my father. Prepare to die.' - swordsman
Mandy Patinkin, in William Goldman's "The Princess Bride" (1987)
