POV-Ray : Newsgroups : povray.binaries.scene-files : AT Devil Plate Server Time
26 Apr 2025 11:53:36 EDT (-0400)
  AT Devil Plate (Message 1 to 3 of 3)
Subject: AT Devil Plate
Date: 4 Apr 2025 10:50:00
Message: <web.67eff108fc8a612c763e4a273b2af915@news.povray.org>
Again I found an other interesting isosurface in Abderrahman Taha's MathMod
which he called Devil Plate (see his functions at the beginning of the attached
pov-file).
But this time I am stuck.
I am posting the pov-file which renders OK although it takes a 'couple
of minutes'. The result is close to the original but
what I could not find out is how to apply thickness
ThickIsoExterior=(Iso(x,y,z,1)*Iso(x,y,z,-1))
and how to apply this condition
F(x,y,z,t) = if(y<(44/10)&y>-(24/10),ThickIsoExterior((10*x/15),y,z,t),1)
Can someone help?
Regards
Droj
Download 'iso_devil_plate.pov.txt' (3 KB)
Subject: Re: AT Devil Plate
Date: 4 Apr 2025 11:45:00
Message: <web.67effe60d1f5ea8e25b4de9225979125@news.povray.org>
That's just a function - like any other.
You might have discontinuities, which would drive the gradient through the roof.
There are likely several ways to go about this.
Enclosing the inequalities in parentheses evaluates them as a Boolean.
If you multiply them, if either one is false, then the product is zero.
If they are both true, then you get 1 * 1 = 1;
so you could try:
F(x,y,z,t) =
select ( (y<(44/10)) * (y>-(24/10)),
0, 1, ThickIsoExterior((10*x/15),y,z,t)
A zero gets added in to use the "4-parameter version" of select, and then since
false = 0, the 1 is the next parameter, and true = 1, so ThickIsoExterior is the
last parameter.
Hope that makes sense.
- BW
select(A, B, C [,D])
It can be used with three or four parameters Select compares the first argument
with zero, depending on the outcome it will return B, C or D. A,B,C,D can be
floats or funtions.
When used with three parameters, if A < 0 it will return B, else C (A >= 0).
When used with four parameters, if A < 0 it will return B. If A = 0 it will
return C. Else it will return D (A > 0).
Date: 5 Apr 2025 08:25:00
Message: <web.67f1205ad1f5ea8e4e78ec763b2af915@news.povray.org>
> so you could try:
> F(x,y,z,t) =
> last parameter.
> - BW
> floats or funtions.
Thanks, B.E.
Now it's clearer what select() is good for.
I have to chew on that for a while.
