POV-Ray : Newsgroups : povray.bugreports : unexpected evaluation of #if(...)? Server Time
13 Mar 2026 11:54:29 EDT (-0400)
  unexpected evaluation of #if(...)? (Message 1 to 9 of 9)
Subject: unexpected evaluation of #if(...)?
Date: 7 Mar 2025 10:55:00
Message: <web.67cb169fa19c01a817bac71e8ffb8ce3@news.povray.org>
The following line results in an negative subscript error when Z = 0:
#if (Z > 0 & VoxelGrid[X][Y][Z-1] > 0)
I expected the evaluation to terminate, with false, at Z > 0.
Won't say it is a bug, it is just unexpected.
ingo
Subject: Re: unexpected evaluation of #if(...)?
Date: 7 Mar 2025 18:10:00
Message: <web.67cb7c0029b385b7f60b1886f712fc00@news.povray.org>
> ingo
I ran into this before. The way I got around it is...
#if(Z>0) #if(array[X][Y][Z-1]>0) do_something.. #end #end
I think it is the negative element of the array is accessed during evaluation
that causes the error.
#ifndef with an array with a negative element or a positive element out of range
will cause an error too. Even throuh clearly element [-1] doesn't exist.
Have Fun!
Date: 7 Mar 2025 19:50:00
Message: <web.67cb935c29b385b7883a5b8389db30a9@news.povray.org>
Hi Ingo
There's some relevant information here:
https://en.wikipedia.org/wiki/Short-circuit_evaluation
In order to program in a more robust and portable way, one should avoid such
constructs that may differ between languages.
I suggest that you split this up into nested #if statements.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 8 Mar 2025 01:30:00
Message: <web.67cbe38f29b385b717bac71e8ffb8ce3@news.povray.org>
Ah, that clarifies.
It will needs some rethinking, nested #if it will be,
thanks,
ingo
Date: 8 Mar 2025 04:37:23
Message: <67cc0fd3$1@news.povray.org>
> Ah, that clarifies.
Above all, it shows that it's VERY language-dependent.
So, splitting conditions seems to be the only solution with POV.
kurtz le pirate
compagnie de la banquise
Date: 8 Mar 2025 06:35:00
Message: <web.67cc2b3e29b385b717bac71e8ffb8ce3@news.povray.org>
But not always straight forward,
#else
after splitting #else may not be reached, where it is in the original (VoxelGrid
= 0).
#if (Z > 0)
  #if (VoxelGrid[X][Y][Z-1] > 0)
#else
it needs some thought and the code is way more complex than this. (#switch #case
can be an alternative after turning the conditions into "states")
ingo
Date: 8 Mar 2025 08:20:00
Message: <web.67cc436329b385b71f9dae3025979125@news.povray.org>
Maybe fall back onto using some small helper macros just to keep the statements
short and the logic straight.
Or, potentially what you could do is multiply the pseudo-Boolean values instead
of using the "&" operator.
0*0 = 0
0*1=1
1*0=0
- BW
Date: 8 Mar 2025 08:55:00
Message: <web.67cc4bca29b385b717bac71e8ffb8ce3@news.povray.org>
> Maybe fall back onto using some small helper macros [...] Or, potentially what
> you could do is multiply the pseudo-Boolean values [...]
We share a line of thought,
ingo
Date: 8 Mar 2025 11:47:04
Message: <67cc7488@news.povray.org>
> #else
> #end
> = 0).
> #if (Z > 0)
>    #end
> #else
> #end
Of corse.
It also depends on what you want to do in the "else" case.
You can also do something like this :
   #if ( VoxelGrid[X][Y][(Z>0?Z-1:OTHER)] > 0 )
More tricky
kurtz le pirate
