POV-Ray : Newsgroups : povray.animations : First animation Server Time
14 Mar 2025 05:01:39 EDT (-0400)
  First animation (Message 1 to 5 of 5)
Subject: First animation
Date: 24 Feb 2025 14:55:00
Message: <web.67bccdd2fed8f419e2bcfe95d91c1e09@news.povray.org>
Hello, im new to this community, but i would like to present you all my first
ever animation! Made with Windows Movie Maker and 13 different scenes to form
frames.
Download 'fall.mp4.dat' (682 KB)
Subject: Re: First animation
Date: 24 Feb 2025 20:10:00
Message: <web.67bd1855c62d4956ae7de1f0f712fc00@news.povray.org>
> frames.
Not bad for your first time! Looking forward to seeing what you else can do with
POV.
Have Fun!
Date: 24 Feb 2025 21:05:00
Message: <web.67bd2439c62d4956e2bcfe95d91c1e09@news.povray.org>
> > frames.
> POV.
> Have Fun!
Thanks for the compliment, im looking forward to doing more!
Date: 24 Feb 2025 21:10:00
Message: <web.67bd25cac62d49561f9dae3025979125@news.povray.org>
> frames.
Use a lot more frames to get a smoother animation.
If it's a falling ball, then it should accelerate as it falls.
See if you can make it bounce with a cyclic animation.
It should slow down as it reaches the top of it's travel, and then accelerate
back down.
Good job making your first animation!
That's pretty much how I started  :)
- BE
Date: 25 Feb 2025 05:02:04
Message: <67bd951c$1@news.povray.org>
> frames.
Reflective sphere on checkered plane? Check. :-)
POV-Ray's inbuilt animation capabilities are worth a look.
//--- this.pov
sphere {  // Explicit movement of 1.0 in x for 9 frames
     <-0.5+(frame_number-1)/8,0.2,2>, 0.2
     pigment { rgb <1,0,0> }
     finish { emission 1 }
sphere {  // Generic movement of 1.0 in x for n frames
     <-0.5+(clock*1.0),-0.2,2>, 0.2
     pigment { rgb <0,1,0> }
// Try the following two commands:
//   povray this.pov +w400 +h300 -p +kff9
//   povray this.pov +w400 +h300 -p +kff18
// The 1st command creates files this1.png  through this9.png.
// The 2nd command creates files this01.png through this18.png.
// +kff specifies the 'final frame' count - which less other
// options is the total frame count - and it triggers the
// rendering of frames for an animation.
Bill P.
