Subject: upgrading to ubuntu 24.04, losing exr library
Date: 13 Oct 2024 10:21:04
Message: <670bd750@news.povray.org>
I resync with povray/master branch to compile on upgraded ubuntu 24.04,
since previous build is now complaining
povray: error while loading shared libraries: libIlmImf-2_5.so.25:
cannot open shared object file: No such file or directory
on config output there is:
checking for pkg-config... pkg-config
checking for OpenEXR's pkg-config... yes
checking for OpenEXR version >= 1.2... 3.1.5, ok
checking for OpenEXR/ImfCRgbaFile.h... yes
checking for ImfInputReadPixels in -lIlmImf... no
configure: WARNING: all program features using the OpenEXR library are
disabled
Is anyone already working on that ?
Subject: Re: upgrading to ubuntu 24.04, losing exr library
Date: 13 Oct 2024 11:54:29
Message: <670bed35$1@news.povray.org>
> disabled
https://github.com/POV-Ray/povray/pull/423
Mostly Ton's work from several years ago, with some help from clipka.
There was a second pull req, IIRC, for v3.7 stable (42?).
Bill P.
> disabled
Could you try the commands
pkg-config --print-provides OpenEXR
pkg-config --libs OpenEXR
and give the results here?
Ton.
