POV-Ray : Newsgroups : povray.binaries.images : A radial pattern contains randomize(bump) Server Time
11 May 2025 18:16:49 EDT (-0400)
  A radial pattern contains randomize(bump) (Message 1 to 10 of 15)
Subject: A radial pattern contains randomize(bump)
Date: 26 Aug 2023 05:15:00
Message: <web.64e9c2855b36d8313a0d3e9baa81652d@news.povray.org>
I suddenly solve an important problem. About how to generate a circle associated
pattern.
I need such a pattern for my wood-pattern generator.
For wood heart, I don't have good function in the past. But these series opens a
window.
Download 'radial associate function.png' (214 KB)
Preview of image 'radial associate function.png'
Subject: Re: A radial pattern contains randomize(bump)
Date: 26 Aug 2023 05:20:00
Message: <web.64e9c33224fd44d93a0d3e9baa81652d@news.povray.org>
Another one. This one superposition two such a bump.
Download 'radial composite function.png' (273 KB)
Preview of image 'radial composite function.png'
Date: 26 Aug 2023 05:30:00
Message: <web.64e9c4ec24fd44d93a0d3e9baa81652d@news.povray.org>
Another one.
In fact I'm not very understand why these function expression generate such
pattern.
Of course I should try to use 2, 3, 4, ... maybe 6~7 bumps superposition.
Download 'radial bump function record3.png' (247 KB)
Preview of image 'radial bump function record3.png'
Date: 26 Aug 2023 05:35:00
Message: <web.64e9c73524fd44d93a0d3e9baa81652d@news.povray.org>
Another situation is ... looks like near degradation.
Using more large number for coefficient of f_external_field.
#declare f_external_field =
function(x, y) {
  2.0*sqrt(x*x + y*y) + 0.2
This one using 2.0, not to mention 3.0, 4.0,...
The color map:
        color_map {
            [0.00 color rgb <0.19, 0.41, 0.89>]
            [0.20 color rgb <0.22, 0.34, 0.62>]
            [0.40 color rgb <0.17, 0.44, 0.55>]
            [0.60 color rgb <0.22, 0.47,0.40>]
            [0.80 color rgb <0.56, 0.33, 0.24>]
            [1.00 color rgb <0.7, 0.15,0.08>]
Download 'raidal composite degradation.png' (117 KB)
Preview of image 'raidal composite degradation.png'
Date: 27 Aug 2023 02:55:00
Message: <web.64eaf31624fd44d94b51e394aa81652d@news.povray.org>
This one is a more special function.
Just like before, the function "f_freq_control_test" is what the output image
shows. And the color_map the same.
          function {f_freq_control_test(x,y,z)}
          color_map {
Download 'bump function power 1-x2.png' (236 KB)
Preview of image 'bump function power 1-x2.png'
Date: 27 Aug 2023 03:30:00
Message: <web.64eafae324fd44d94b51e394aa81652d@news.povray.org>
Because my mathematics is not so good, so I need spend so many years to think
these composite(I just try something I prepare for other concept).
The result yesterday is surprising me.
Download 'ellipse bump function.png' (805 KB)
Preview of image 'ellipse bump function.png'
Date: 27 Aug 2023 07:31:00
Message: <64eb33f4@news.povray.org>
Op 26-8-2023 om 11:14 schreef And:
> pattern.
> window.
I think you are doing alright with this series of experiments.
Integrating these functions (or combination of functions) in your
wood-pattern generator will be interesting. Have you already done this?
I would be interested to see how that looks.
Date: 27 Aug 2023 12:30:00
Message: <web.64eb791424fd44d91f9dae3025979125@news.povray.org>
> pattern.
> window.
Hi And,
These are interesting pattern experiments, and I'm looking forward to seeing
what you come up with.
I find it interesting to see the pattern that you have here, as I didn't
understand how the effect was being generated from a circular base pattern.
I coded your pattern into a scene, and for some reason, did not get the same
result.  Perhaps you could post the full code of a working scene.
Also, if you could describe the exact type of pattern that you are looking to
make, it would be easier to help you develop something through a logical
elaboration of a base pattern function.
I started with an atan2 (x, y) function, as that will give you a radial pattern
to start with.
#version 3.8;
global_settings {assumed_gamma 1.0}
default {finish {diffuse 1}}
#include "functions.inc"
 location <0, 0, -10>
 up y
 look_at <0, 0, 0>
light_source {<0,  1, -50> rgb 1.0}
sky_sphere {pigment {rgb 1}}
#declare C = function {0.5 - sqrt (x*x+y*y) + 0.1}
#declare W1 = function {f_bumps (x/C(x, y, z), y/C(x, y, z), z)}
#declare Freq = 20;
#declare Ang = function {atan2 (x, y)/(tau/Freq)}
#declare W2 = function {f_bumps (Ang (x, y, z), Ang (x, y, z), z)}
#declare Wood1 =
color_map {
 [0.00 srgb <249, 210, 173>/255]
 //[0.25 srgb <249, 210, 173>/255]
 [0.25 srgb <252, 156, 173>/255]
 //[0.50 srgb <252, 156, 173>/255]
 [0.50 srgb <206, 126,  72>/255]
 //[0.75 srgb <206, 126,  72>/255]
 [0.75 srgb <113,  51,  24>/255]
 //[1.00 srgb <113,  51,  24>/255]
plane {z, 0 pigment {function {W1(x, y, z)} color_map {Wood1}} }
//plane {z, 0 pigment {function {W2(x, y, z)} color_map {Wood1}} }
Attached is what I get when I try to use the functions posted here.
Download 'radialfunctions.png' (108 KB)
Preview of image 'radialfunctions.png'
Date: 27 Aug 2023 13:30:41
Message: <64eb8841$1@news.povray.org>
That's not surprising for me. That's a formula for an ellipse that you
got there for f_external_field.
Date: 28 Aug 2023 10:10:00
Message: <web.64eca9e624fd44d989131d8aaa81652d@news.povray.org>
> Thomas
Thank you... I have not integrated these function with my wood-pattern generator
yet.
In fact, I'm not sure the shape of such patterns in three dimensions. I need
researching and think more.
