POV-Ray : Newsgroups : povray.binaries.images : brain bot progress rendering Server Time
11 May 2025 17:59:41 EDT (-0400)
  brain bot progress rendering (Message 1 to 10 of 19)
Subject: brain bot progress rendering
Date: 18 Jul 2023 00:00:00
Message: <web.64b60deeb2bd6c99b5177e91dabc9342@news.povray.org>
Current modeling progress for a brain bot character. Using Blender to array the
cubic spline sweeps and lathes. Still messing with the scale of the brain folds.
The tentacle arms are an intersection using a spline sweep that clips spheres
plotted along the same path.
Miller
Download 'brain_bot_progress.png' (1899 KB)
Preview of image 'brain_bot_progress.png'
Subject: Re: brain bot progress rendering
Date: 18 Jul 2023 08:50:24
Message: <64b68a90$1@news.povray.org>
Great work!
Date: 18 Jul 2023 09:45:00
Message: <web.64b6964741b179ef226d95dcedfc8715@news.povray.org>
Looking great, you're really nailing that pulp sci-fi vibe!
Date: 18 Jul 2023 17:30:00
Message: <web.64b703cd41b179eff8c47d526e741498@news.povray.org>
> Miller
It's looking really good!
How are you modeling the brain?
Sam
Date: 18 Jul 2023 22:05:00
Message: <web.64b7441141b179efb5177e91dabc9342@news.povray.org>
> > Miller
> Sam
Thanks,
the brain is one continuous sphere_sweep/cubic_spline. I used Blender with
object snap to plant spheres on a simple brain shape surface. I image-mapped the
surface to help guide the process of plotting out the gray matter folds. I
exported the spheres via .x3d and converted the file to POV syntax. Attached is
a capture of the brain in Blender. Still tweaking a bit. I'm only modeling what
I the final camera will see. I'm currently working on the weapon at the end of
the tenacle arms.
Mike
Download 'brain_progress.png' (1430 KB)
Preview of image 'brain_progress.png'
Date: 19 Jul 2023 08:35:51
Message: <64b7d8a7$1@news.povray.org>
Op 19-7-2023 om 04:01 schreef Mike Miller:
>> Sam
> Thanks,
> the tenacle arms.
> Mike
Smart! I am impressed.
Date: 19 Jul 2023 19:50:00
Message: <web.64b875bc41b179eff8c47d526e741498@news.povray.org>
> > > Current modeling progress for a brain bot character. [...]
> Thanks,
> the tenacle arms.
> Mike
Ah, tracing the brain folds is a good solution, for sure.
I know nothing about the .x3d file type, but it sounds like it somehow preserves
lots of info including ordered point arrays? Or it can at least be converted to
arrays?
Sam
Date: 20 Jul 2023 11:25:00
Message: <web.64b94f0c41b179efb5177e91dabc9342@news.povray.org>
> > Thanks,
> > the tenacle arms.
> > Mike
> arrays?
> Sam
Yes, you are correct. The .x3d holds all the naming and transform information
of the Blender types. As long as you stick with Blender primitives (blobs,
spheres, torus, cube, etc. the output file is simple to parse. I use it to
export point arrays for POV lathes, sweeps, prisms, 2D arrays. I wrote a
converter that reads the .x3d and writes POV syntax. Attached shows spheres
renamed as 'pointData in Blender... I convert the points into 'mixed array' to
be used in a construction loop.
Currently working on some sci-fi tower forms
// convert .x3d
#declare pointDataCount = 12 ;
#declare pointArray = array mixed [pointDataCount][2] ;
#declare pointArray[0][0] = <21.561, -4.214, 0.159>  ;
#declare pointArray[0][1] = 2.285 ;
#declare pointArray[1][0] = <24.891, -4.027, 0.112>  ;
#declare pointArray[1][1] = 2.162 ;
#declare pointArray[2][0] = <28.244, -3.671, 0.020>  ;
#declare pointArray[2][1] = 1.930 ;
#declare pointArray[3][0] = <31.605, -3.120, -0.142>  ;
#declare node = sphere {<0,0,0> 1.6} ;
#declare arm_right =
intersection {
    union {
        #for (i,0,pointDataCount-1)
            object {node scale pointArray[i][1]*.9 translate pointArray[i][0]}
        material {M_red_metal}
Currently working on some sci-fi tower forms.
Mike.
Download 'weird world - pov-blender_comp.jpg' (740 KB)
Preview of image 'weird world - pov-blender_comp.jpg'
Date: 20 Jul 2023 14:35:00
Message: <web.64b97d3141b179efb5177e91dabc9342@news.povray.org>
> > Thanks,
> > the tenacle arms.
> > Mike
> arrays?
> Sam
In Blender, I array a sphere along a bezier path with the 'curve' modifier.
Collapsing the array and curve moodier to create a list of loose elements still
maintains a creation order. Prefect for lathes, sweeps, prisms, ect.
Miller
Date: 20 Jul 2023 18:20:00
Message: <web.64b9b29941b179eff8c47d526e741498@news.povray.org>
> > > Thanks,
> > > the brain is one continuous sphere_sweep/cubic_spline. [...] I exported the
> > > spheres via .x3d and converted the file to POV syntax. [...]
> > arrays?
> Yes, you are correct. The .x3d holds all the naming and transform information of
> the Blender types. As long as you stick with Blender primitives (blobs, spheres,
> torus, cube, etc. the output file is simple to parse. I use it to export point
> arrays for POV lathes, sweeps, prisms, 2D arrays. I wrote a converter that reads
> the .x3d and writes POV syntax. Attached shows spheres renamed as 'pointData in
> Blender... I convert the points into 'mixed array' to be used in a construction
> loop.
> Miller
That's some welcome information! Years ago, I made a Blender-to-.pov arrays
script in Python to transport object orientation data to POV-Ray (for rigid body
sims), but Blender's Python API changed over time, and the script stopped
working :( The .x3d file type seems like a promising replacement, and might even
be less work than finding the changed API calls all over again.
It's looking more interesting all the time.
Sam
