POV-Ray : Newsgroups : povray.general : What is this strangeness? Server Time
25 Nov 2026 03:29:11 EST (-0500)
  What is this strangeness? (Message 1 to 5 of 5)
Subject: What is this strangeness?
Date: 3 Nov 2026 11:15:49
Message: <6aea08b5$1@news.povray.org>
Hello,
I spent some time trying to figure out why my code was producing bizarre
results. It couldn't be simpler. It fits on a single line :
	#declare y0 = a*x0*+b;
Of course, there are no syntax errors.
A typo left an “*” after the x0.
What I don't understand is the calculation involving that extra “*”
With a = 0.51, b = 10.66 and  x0 =  -16.25, the correct calculation
yields 2.37 and with the extar "*", -88.34 !
Where's the logic? I haven't been able to find a connection between the
two values, so I don't understand what operation this * performs.
I'm sure the people here have already figured it out and will be able to
explain it to me. Thanks
klp
compagnie de la banquise
Subject: Re: What is this strangeness?
Date: 3 Nov 2026 12:40:00
Message: <web.6aea1c252c634b29d2f83f61f712fc00@news.povray.org>
kurtzlepirate <kur### [at] freefr> wrote:
> Hello,
> klp
It seen POV's parser just ignores the plus in your equation
 a*x0*+b becomes a*x0*b which is -88.34
drop the * and you get a*x0+b which is the 2.37
Try #declare y0 = a*x0*-b; and you'll get 88.34
Try #declare y0 = a*x0+*b; and you'll an Parser Error
Some parsers can't handle the '*+' syntax and crash. It has happen to me But I
can't remember when or where:)
Have Fun!
Date: 3 Nov 2026 12:50:00
Message: <web.6aea1e472c634b2975a02fd89db30a9@news.povray.org>
> Hello,
It is just one more multiplication. The last plus sign is here the unary plus
operator. The unary minus operator negates the operand, the unary plus operator
does not.
This is a valid expression:  2 * -3 = -6
- and so is this:  2 * +3 = +6 = 6
https://www.geeksforgeeks.org/c/unary-operators-cc/#unary-plus
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 3 Nov 2026 13:05:00
Message: <web.6aea21172c634b29ac7cd2e9f712fc00@news.povray.org>
> > Hello,
> > A typo left an �*� after the x0.
> > What I don't understand is the calculation involving that extra �*�
> > klp
> Have Fun!
I couldn't let it go. I had to try something.
 #declare y0 = a*x0*+++++++++++b; & #declare y0 = a*x0*-----------b;
Both work, kind of :}
Date: 4 Nov 2026 06:27:22
Message: <6aeb169a$1@news.povray.org>
Hello,
That's exactly right.
In fact, the code is interpreted as #declare y0 = a * x0 * (+b);
That makes perfect sense.
Another problem with understanding the mechanism is that i used the
actual values from my code. If i use simpler values, it becomes much
clearer right away. First, with a = 1, we eliminate one parameter; then,
with b = 2 and x0 = 3, we get y0 = 3 + 2 = 5 vs y0 = 3 * 2 = 6.
Tor, Leroy, thank you both very much for your suggestions.
klp
