POV-Ray : Newsgroups : povray.animations : Disintegration Macro Server Time
27 Oct 2026 20:51:03 EDT (-0400)
  Disintegration Macro (Message 1 to 3 of 3)
Subject: Disintegration Macro
Date: 26 Oct 2026 23:30:00
Message: <web.6ae01a4334646e36c6d4b12d7c04d41a@news.povray.org>
I used claude.ai to create the following disintegration macro.  I really was
just curious if it even knew POVRay, and it turns out it knows it REALLY WELL!
This was the last piece I needed for a very large animation I'm working on for a
music video.  Whatever your opinion on AI coding, I gotta say this is damn good
code (I've been a professional programmer for >40 years).  Only thing I added
was the optional debug outputs.
Wanted to give it back to the community.
-- Emory
// disintegrate.inc  --  tear a solid object apart and blow it along a vector
// POV-Ray 3.7+. Stateless: everything is computed from T, so it animates with
clock.
// Disintegrate(Obj, Dir, Step, T, Start, Sweep, Jitter, Life, Min_Scale, Speed,
Spread, Spin, Accel, Seed, Cut_Tex, Shards)
//   Obj      a declared, finite, SOLID object (#declare Obj = ...). Its texture
is kept on the pieces.
//   Dir      direction the pieces travel; the tear starts at the downstream end
and sweeps back
//   Step     size of the cubic cells the object is cut into (smaller = more,
finer pieces) -- but also the slice thickness along Dir
//   T        current time in seconds (e.g. clock * 4)
//   Start    time the tearing begins
//   Sweep    seconds for the tear front to cross the whole object
//   Jitter   random extra delay per piece in seconds (ragged, uneven tearing)
//   Life     seconds over which a piece shrinks from full size to nothing after
release
//   Min_Scale  a piece is not drawn once its scale (1 at release, 0 at Life) is
<= this value
//              (e.g. 0.05); use 0 to draw until the piece reaches zero size
//   Speed    average launch speed along Dir (units/sec)
//   Spread   sideways scatter, as a fraction of Speed (0 = straight, 0.5 = very
chaotic)
//   Spin     tumble rate in degrees/sec
//   Accel    constant acceleration vector, e.g. <0,-3,0> for gravity or Dir*2
for wind
//   Seed     integer random seed
//   Cut_Tex  texture for the faces created by cutting (and for plain cubes when
Shards = 0)
//   Shards   1 = pieces are the real object cut into cubes (keeps its shape and
texture)
//            0 = plain cubes using Cut_Tex (much faster to render)
// This code was written by claude.ai, prompted by Emory Stagmer (aka
VAXHeadroom)
// October 2026
#ifndef (DISINTEGRATE_DEBUG)
#declare DISINTEGRATE_DEBUG=false;
#declare DISINTEGRATE_DEBUG_2=false;
#include "math.inc"   // for clamp()
#macro Disintegrate(Obj, Dir, Step, T, Start, Sweep, Jitter, Life, Min_Scale,
Speed, Spread, Spin, Accel, Seed, Cut_Tex, Cut_Int, Shards)
  #local Dn   = vnormalize(Dir);
  #local Pmin = min_extent(Obj);
  #local Pmax = max_extent(Obj);
  #local H    = Step / 2;
  // Extent of the object measured along Dir
  #local Smin = 1e9;
  #local Smax = -1e9;
  #for (C, 0, 7)
    #local Q = <(mod(C,2) = 0 ? Pmin.x : Pmax.x),
                (mod(floor(C/2),2) = 0 ? Pmin.y : Pmax.y),
                (C < 4 ? Pmin.z : Pmax.z)>;
    #local Smin = min(Smin, vdot(Q, Dn));
    #local Smax = max(Smax, vdot(Q, Dn));
  #local Range = max(Smax - Smin, 0.0001);
  // 1) The part of the object the tear front hasn't reached yet
  #local Front = Smax + 0.001 - clamp((T - Start) / Sweep, 0, 1) * Range;
  #if ((T - Start) < Sweep)    // once the front has crossed the object, nothing
intact remains
    intersection {
      object { Obj }
      plane { Dn, Front }
      texture { Cut_Tex }          // only used on the cut face
#if( DISINTEGRATE_DEBUG )
#debug concat("DI: Pmin:<",str(Pmin.x,4,4),  ",", str(Pmin.y,4,4), ",",
str(Pmin.z,4,4),">\n")
#debug concat("DI: Pmax:<",str(Pmax.x,4,4),  ",", str(Pmax.y,4,4), ",",
str(Pmax.z,4,4),">\n")
#debug concat("DI: Front: ",str(Front,4,4),"\n")
#debug concat("DI: Smin:  ",str(Smin,4,4),"\n")
#debug concat("DI: Smax:  ",str(Smax,4,4),"\n")
#debug concat("DI: Range: ",str(Range,4,4),"\n")
#debug concat("DI: T   :  ",str(T,4,0),"\n")
#debug concat("DI: Start:  ",str(Start,4,0),"\n")
#debug concat("DI: Sweep:  ",str(Sweep,4,0),"\n")
  // 2) The flying pieces
  #local R  = seed(Seed);
  #local Nx = int(ceil((Pmax.x - Pmin.x) / Step));
  #local Ny = int(ceil((Pmax.y - Pmin.y) / Step));
  #local Nz = int(ceil((Pmax.z - Pmin.z) / Step));
  #for (Ix, 0, Nx-1)
    #for (Iy, 0, Ny-1)
      #for (Iz, 0, Nz-1)
        #local P   = Pmin + <Ix + 0.5, Iy + 0.5, Iz + 0.5> * Step;
        #if (Shards)
          // Real shards: every cell is intersected with the object. Cells that
lie
          // outside it come out empty, so no inside() test is needed.
          #local Hit = 1;
        #else
          // Plain cubes: keep cells whose centre or any corner is inside the
object
          #local Hit = inside(Obj, P);
          #for (C, 0, 7)
            #if (Hit = 0)
              #local Hit = inside(Obj, P + <mod(C,2) - 0.5, mod(floor(C/2),2) -
0.5, floor(C/4) - 0.5> * Step * 0.98);
        #if (Hit)
          #local U   = (Smax - vdot(P, Dn)) / Range;     // 0 = downstream end,
1 = upstream end
          #local Tr  = Start + U*Sweep + rand(R)*Jitter; // release time
          #local Vsp = Speed * (0.5 + rand(R));
          #local Jt  = <rand(R) - 0.5, rand(R) - 0.5, rand(R) - 0.5> * 2;
          #local Rt  = <rand(R) - 0.5, rand(R) - 0.5, rand(R) - 0.5> * 2 * Spin;
          #local Age = T - Tr;
          #local Sc = 1 - Age/Life;                    // 1 at release, 0 at
Life
#if( DISINTEGRATE_DEBUG_2 & Ix=0 & Iy=0)
#debug concat("DI: Age       :  ",str(Age,4,4),"\n")
#debug concat("DI: Sc        :  ",str(Sc,4,4),"\n")
#debug concat("DI: Min_Scale :  ",str(Min_Scale,4,4),"\n")
          #if ((Age >= 0) & (Sc > Min_Scale))
            #local Off = (Dn*Vsp + Spread*Speed*Jt) * Age + 0.5*Accel*Age*Age;
            #if (Shards)
              intersection {
                box { P - <H,H,H>, P + <H,H,H> }
                object { Obj }
                texture { Cut_Tex }
                //interior { Cut_Int }
                translate -P
                scale Sc
                rotate Rt * Age
                translate P + Off
            #else
              box {
                <-H,-H,-H>, <H,H,H>
                texture { Cut_Tex }
                scale Sc
                rotate Rt * Age
                translate P + Off
Subject: Re: Disintegration Macro
Date: 27 Oct 2026 07:40:00
Message: <web.6ae08d1ca54f3a29be3cb90a7bb7ede7@news.povray.org>
I was curious and still am, but after 15 minutes of trial and error I didn't get
any result.
Do you have a working example?
Without it, such code snippets with dozens of macro parameters are rather
useless.
The last of my attempts:
#local oTest = sphere { 0,1 translate y*0 pigment { color rgb <1,1,0> } }
#local txCut = texture { pigment { color rgb <1,0,1> } }
//Disintegrate(Obj, Dir, Step, T, Start, Sweep, Jitter, Life, Min_Scale, Speed,
Disintegrate(oTest, <0,1,0>, 100, 1.3, 2, 3, 5, 100, 0.1, 0.1, 5, 20, <0,1,0>,
7, txCut, 10, 100)
m
Download 'disintegrate.png' (9 KB)
Preview of image 'disintegrate.png'
Date: 27 Oct 2026 15:24:52
Message: <6ae0fa84$1@news.povray.org>
Am 27.10.26 um 12:38 schrieb Maetes:
> any result.
> useless.
> 7, txCut, 10, 100)
> m
If you are interested in a working explode-macro you may have a look at
a very old code by Chris Colefax:
https://geocities.restorativland.org/SiliconValley/Lakes/1434/explode.html
Example code is given there. Thanks to Cousin Ricky for for digging up
the link.
Best regards from 200 km to the southeast,
Michael
