POV-Ray : Newsgroups : povray.text.scene-files : Asteroid - textures and problems Server Time
16 Nov 2026 19:07:52 EST (-0500)
  Asteroid - textures and problems (Message 1 to 15 of 15)
Subject: Asteroid - textures and problems
Date: 29 Jul 2026 07:35:00
Message: <web.6a69e5033e83e020cce36e0930225ff5@news.povray.org>
Hi Ladies
I'm currently trying to design an asteroid.
I created the mesh with the rock generator from John "Evil Snack", see website:
https://www.geocities.ws/evilsnack/inc.htm
The result looks reasonably good, but improvements would be possible.
Maybe one of you has some ideas.
1. Dark triangles
Especially in movies you can see that it is built up of triangles.
First they are black, and less than a degree of rotation further they are
bright.
This may not be particularly noticeable in individual frames, but in movies it
is annoying.
I have already set the number of triangles very high, more is hardly possible.
Are there other ways to improve the mesh or other scripts to create it?
2. Textures
I've already played around with textures a bit, but I'm not completely
satisfied.
Does anyone have any textures for a similar use that they would like to share?
If the final result is presentable, I will of course publish it on my website
sooner or later.
Then others would also benefit from your ideas.
A short film is available here:
https://www.maetes.com/stuff/povray_forum_26_asteroid.mp4
8.4 MB, 24 seconds, 30 fps
Attached is a zip with my test environment, cropped to the bare minimum.
It can be executed via terminal with:
povray +Ies_generator_rock_examples_nano.pov +Otest/es_rock_nano_00.png +w1920
+h1080 -GR +A
Have a nice day,
Ma
Download 'povray_maetes_asteroid_example.7z.zip' (2120 KB)
Subject: Re: Asteroid - textures and problems
Date: 29 Jul 2026 07:40:00
Message: <web.6a69e5bde23b9251cce36e0930225ff5@news.povray.org>
Here one of the results
Download 'es_rock_00.png' (1257 KB)
Preview of image 'es_rock_00.png'
Date: 29 Jul 2026 07:45:00
Message: <web.6a69e6f9e23b9251cce36e0930225ff5@news.povray.org>
and another
Download 'es_rock_nano_00.png' (457 KB)
Preview of image 'es_rock_nano_00.png'
Date: 29 Jul 2026 11:21:36
Message: <6a6a1a80$1@news.povray.org>
Le 2026-07-29 à 07:33, Maetes a écrit :
> Hi Ladies
> 1. Dark triangles
> bright.
> is annoying.
Unavoidable when using meshes. Those dark/black triangles are just
triangles that are physically facing away from the light, even if their
normals are oriented toward the light.
Using an area_light with the area_illumination MAY help. Adjust the
extent of the light until your results are acceptable. That area_light
need to have the circular attribute. Be sure to use adaptive 0. Don't
fear using something like 65x65, or more, for the number of elements.
With adaptive 0, most of the time, only the corners will be evaluated.
> 2. Textures
> satisfied.
As a lot of asteroids are really just big balls of gravel, some gravel
based textures should be pretty realistic.
Date: 30 Jul 2026 02:07:25
Message: <6a6aea1d$1@news.povray.org>
On 29.07.2026 14:33, Maetes wrote:
> 2. Textures
> satisfied.
I guess you can use Phobos and Deimos photos as some source for ideas.
They are quite like asteroids but have more extensive portfolio.
In general, I suspect that slops and normals may disguise triangle
flatness pretty well.
Ilyich the Toad
https://dnyarri.github.io/
Date: 30 Jul 2026 09:30:00
Message: <web.6a6b511ce23b9251f58bc24b25979125@news.povray.org>
"Maetes" <nomail@nomail> wrote:
> 1. Dark triangles
What if you used an isosurface? Then you could do away with triangles completely
and have "infinite resolution".
> 2. Textures
> satisfied.
I'd just start searching the forums for rocks, asteroids, meteors, and any other
sort of concrete, brick, mortar textures.
Be sure to add normals to your object, and don't underestimate how strongly
lighting affects how things appear.
- BE
Date: 31 Jul 2026 05:40:31
Message: <6a6c6d8f$1@news.povray.org>
By increasing the number of triangles and thus the accuracy ?
Two sets of macros that can be used for this :
* The New (and Improved!) Surface Subdivision Suite
* The Catmull-Clark Surface Subdivision Suite
On John's website :
<https://www.geocities.ws/evilsnack/index.htm#POVRAY>
kurtz le pirate
compagnie de la banquise
Date: 31 Jul 2026 06:40:00
Message: <web.6a6c7abfe23b9251d1d09a9825979125@news.povray.org>
Yes, but as he stated in the sentence immediately prior:
"I have already set the number of triangles very high, more is hardly possible."
so it looks to me like he needs to move from a fixed geometry to an implicit or
interpolative one.
- BE
Date: 1 Aug 2026 10:43:03
Message: <6a6e05f7$1@news.povray.org>
I read it too quickly and it was poorly translated. Sorry.
kurtz le pirate
Date: 3 Aug 2026 12:00:00
Message: <web.6a70b9f4e23b9251cce36e0930225ff5@news.povray.org>
I have little experience with Area Light so far, but maybe it's worth a try.
But the render time increases again.
I started with meshes because I found the rock generator and wanted to try it.
I would not have thought that you would see the triangles so well.
Here in the forum I found an isosurface asteroid and it actually looks quite
good, see picture.
Maybe I can improve it further, use it as an object in the foreground and
because of faster rendering time use the meshes for more distant objects.
https://news.povray.org/povray.binaries.images/thread/%3C449ebecf@news.povray.org%3E?mtop=10&moff=10
I also looked for textures, which I didn't find right away.
I came across this page that shows the built-in textures, very helpful.
https://povray.tashcorp.net/library/stones.inc/
This link
I have to take a closer look, looks like more training time.
Thanks for all the tips.
M
Download 'es_rock_00.png' (442 KB)
Date: 3 Aug 2026 13:15:00
Message: <web.6a70cbd3e23b9251d1d09a9825979125@news.povray.org>
What about these?
https://hof.povray.org/pebbles.html
Date: 3 Aug 2026 13:35:00
Message: <web.6a70d0f5e23b9251cce36e0930225ff5@news.povray.org>
> What about these?
No sourcecode,
and "took 4.5 days to render"
maybe 4.5 days was 20 years ago, but even a minute is to long for me
(movies?)
m
Date: 3 Aug 2026 15:45:00
Message: <web.6a70ef90e23b9251d1d09a9825979125@news.povray.org>
https://news.povray.org/povray.text.scene-files/thread/%3C48d158e3%241%40news.povray.org%3E/?ttop=447197&toff=200
I used the source to do this scene
https://news.povray.org/povray.binaries.images/thread/%3Cweb.5d3c5fe27be432e04eec112d0%40news.povray.org%3E/?ttop=44797
9&toff=700
Didn't take that long to render IIRC.
- BE
Date: 4 Aug 2026 07:30:00
Message: <web.6a71cc4ee23b9251cce36e0930225ff5@news.povray.org>
Whow, great, thanks for that.
I had to quit the execution of the script, after more than 3 minutes it was
parsing and parsing ...
But I can probably separate the textures and test them one by one on the
asteroid. If I have new results, I show them, of course.
I'm also a little further along with the iso-asteroid, looked which numbers I
have to change to make it more unround.
Thanks again,
Martin
Download 'es_rock_00.png' (679 KB)
Date: 4 Aug 2026 14:59:42
Message: <6a72369e$1@news.povray.org>
Over 3 minutes of parsing ? Check if you have some infinite loop
somewhere. That or a MASSIVE mesh with several million of triangles.
Before parsing the mesh, add a debug statement to display the number of
triangles and vertices.
Within any loop, add a debug to show you a loop counter every 100, 200,
500 or 1000 iterations.
