POV-Ray : Newsgroups : povray.animations : Animation with sine waves? Server Time
16 Nov 2026 19:07:51 EST (-0500)
  Animation with sine waves? (Message 1 to 9 of 9)
Subject: Animation with sine waves?
Date: 23 Jul 2026 00:35:00
Message: <web.6a619842b7fdf4e0e541bb4fe358f448@news.povray.org>
Hello POV-Ray Users!
So, i was rendering an animation of a metronome whose pendulum swings back and
forth between a specific angle and its negative.
Here's how I did it:
#declare maxangle = 35;
#declare actangle = maxangle * sin( clock * 4 ) * cos( clock * 4 );
polygon {
5,
<-.06,0>, <-.06,2.6>, <.06,2.6>, <.06,0>, <-.06,0>
         texture{ Chrome_Metal
                  // normal { bumps 0.5 scale 0.05 }
                  // finish { phong 1 }
                } // end of texture ---------------------------
    translate <0,0,0>
    rotate <0,0,clock*actangle>
    translate <0,.3,-.8>
object { metronome
scale .5 }
This is not the complete scene, just the pendulum, which is a polygon that
rotates (maxangle value).
(I'm not an experienced user, and I don't know much about trigonometry and stuff
like that, srry.)
However, the pendulum doesn't swing back and forth constantly (as it should);
instead, it moves a very short distance at the beginning of the animation, and
as the animation progresses, the distance it travels increases until it exceeds
the angle that had been set (or so I think) as the maximum.
If anyone knows what's going on and how to fix it, I would really appreciate
it if you could share your knowledge with me.
Thanks!
(sorry if my english is bad, most of this post was translated)
- S I R ?
Subject: Re: Animation with sine waves?
Date: 23 Jul 2026 01:35:00
Message: <web.6a61a77230cd75d17bac71e8ffb8ce3@news.povray.org>
Didn't analyse the full thing but noticed the clock as well in actangle as in
rotate again. So you animate the animation, removing the clock from rotate might
do the trick?
ingo
Date: 23 Jul 2026 06:10:00
Message: <web.6a61e78c30cd75dd1d09a9825979125@news.povray.org>
> do the trick?
> ingo
Also, why is sin getting multiplied by cos?
I would just use cos to oscillate between 1 and -1.
- BE
Date: 25 Jul 2026 05:53:25
Message: <6a648795$1@news.povray.org>
Hello 'Sir Francisco',
I think you're making things harder on yourself....
For exemple :
// 50 degrees -> +/- 25 deg or something else, of course
#declare Amplitude = 50;
#declare HalfAmplitude = Amplitude*0.50;
Object to animate is "Object"
object {
   Object
   rotate sin(clock*tau)*HalfAmplitude*z
'clock' from 0.0 to 1.0
In this exemple, oscillations is around z-axis.
I hope this helps...
kurtz le pirate
compagnie de la banquise
Download 'metronome.mp4.dat' (45 KB)
Date: 28 Jul 2026 23:25:00
Message: <web.6a69725e30cd75d7f56ebe5e3a3be07@news.povray.org>
> > do the trick?
> > ingo
> - BE
I don't really know why, i just messed up with something i don't even
know about :(
Also, thanks for your time and patience!
- S I R ?
Date: 28 Jul 2026 23:30:00
Message: <web.6a69731130cd75d7f56ebe5e3a3be07@news.povray.org>
> do the trick?
> ingo
Sorry, i didn't knew what i was doing
- S I R ?
Date: 28 Jul 2026 23:40:00
Message: <web.6a69750e30cd75d7f56ebe5e3a3be07@news.povray.org>
> For exemple :
> object {
>    Object
> kurtz le pirate
Thanks! i tried it and it worked!
If you don't mind, could you explain to me how it works?
- S I R ?
Date: 29 Jul 2026 06:45:00
Message: <web.6a69d8ce30cd75dd1d09a9825979125@news.povray.org>
You want the pendulum to swing over a certain amount on both sides.
kurtz defines the included angle as "Amplitude" and then takes half of that as
the amount it swings to either side.
> > object {
> >    Object
So now he places the Object in the scene, and to rotate it in the animation, he
creates an equation using the clock variable.
if you point at your screen, your arm an finger are in the direction of the z
axis.  So rotating around z rotates things in the plane of your screen.
By how much?
Well the max is "HalfAmlitude".
And we want to go from 0 to HalfAmplitude to 0 to -HalfAmplitude to 0 to .....
A circle is 2*pi radians around in angular units. (tau = 2*pi)
plotting sin on a unit circle goes from 0 to 1 to 0 to -1 to 0 to ....
So as the clock variable increases from 0 to 1, we take that and multiply it by
tau.  That gives us a value that goes from 0 to tau.
Taking the sin of that gives us a value that goes from 0 to 1 to 0 to -1 to 0 to
then multiplying that by HalfAmplitude gives us a value that goes from 0 to
and of course we need a vector to pass to "rotate", and so we multiply by z
Date: 30 Jul 2026 04:13:44
Message: <6a6b07b8$1@news.povray.org>
>>> object {
>>>     Object
> By how much?
Perfect BE. I couldn't have said it better myself
kurtz le pirate
