POV-Ray : Newsgroups : povray.text.scene-files : Roman numerals Server Time
17 Mar 2026 13:27:17 EDT (-0400)
  Roman numerals (Message 1 to 10 of 14)
Subject: Roman numerals
Date: 19 Dec 2025 18:20:00
Message: <web.6945dcb042cb8f7352af7e976cde94f1@news.povray.org>
hi,
I wrote/"needed" a macro ('LatinYear()') to convert years to their Roman
numerals representation, posting it .. just in case.  the macro takes the year
and returns a string, for instance:
#version 3.8;
global_settings {assumed_gamma 1}
#include "latinum.inc"
#debug concat("2000  ",LatinYear(2000),".\n")
#debug concat("1984  ",LatinYear(1984),".\n")
#debug concat("2026  ",LatinYear(2026),".\n")
enjoy, jr.
Download 'latinum.inc.txt' (3 KB)
Subject: Re: Roman numerals
Date: 20 Dec 2025 05:23:25
Message: <6946791d$1@news.povray.org>
On 20/12/2025 00:16, jr wrote:
> hi,
> #version 3.8;
> enjoy, jr.
Good work, a little too complicated, but good work.
kurtz le pirate
compagnie de la banquise
Date: 20 Dec 2025 07:30:00
Message: <web.6946962b6fb404d152af7e976cde94f1@news.povray.org>
hi,
> > I wrote/"needed" a macro ('LatinYear()') ...
thank you, very much.  you're right, of course.  attached an update, less
"cruft" :-).  also I got rid of the '#for', and the macro can now be used with
version 3.7 too (tested with v3.7.0.8).
enjoy, jr.
Date: 20 Dec 2025 09:25:00
Message: <web.6946b1256fb404d11f9dae3025979125@news.povray.org>
This is quite synchronicitous - I was just musing about doing Roman Numerals the
other day.
Chalked it up to "add to to do list", and "surely someone else has done this
before".  And promptly got interrupted with something else to do.
Not sure if this helps any - read the last sentence:
https://wiki.povray.org/content/Documentation_Talk:Reference_Section_2.3
- BE
Date: 20 Dec 2025 11:47:22
Message: <6946d31a$1@news.povray.org>
On 20/12/2025 13:27, jr wrote:
> hi,
> enjoy, jr.
what do you think of this version?
// --- macro start
#macro ToRoman(DecimalToConvert)
  #local Nb = 13;
  #local values = array[Nb] {1000,900,500,400,100,90,50,40,10,9,5,4,1};
  #local symbols = array[Nb]
{"M","CM","D","CD","C","XC","L","XL","X","IX","V","IV","I"};
  #local roman = "";
  #local num = DecimalToConvert;
  #local i = 0;
  #while ( i<Nb & num>0 )
   #while( values[i] <= num )
    #local num = num - values[i];
    #local roman = concat(roman,symbols[i]);
   #local i = i + 1;
  roman
// --- macro end
#declare D = 10191; // beginning of the Dune Story
#declare R = ToRoman(D);
#debug concat(str(D,0,0)," -> ",R,"\n")
...of course, valid only for positive years.
kurtz le pirate
Date: 20 Dec 2025 12:31:06
Message: <6946dd5a$1@news.povray.org>
>> hi,
>> used with
>> enjoy, jr.
> // --- macro start
>   #local Nb = 13;
>   #local roman = "";
>   #local i = 0;
>    #end
>    #local i = i + 1;
>   #end
>   roman
> #end
> // --- macro end
Just use the absolute value of the year and add «BCE» for the negative
years.
-2027 → MMXXVII BCE
Now, need a font supporting macron for years 1 000 000 to 999 999 999.
And double macron for years 1 000 000 000 to 999 999 999 999.
Date: 20 Dec 2025 17:55:00
Message: <web.694728d36fb404d152af7e976cde94f1@news.povray.org>
hi,
several things.  </grin>  first, it was fun to compare (thanks) and find the old
"swings and roundabouts" adage confirmed.
it is pretty neat, the all-in-one macro.  pretty compact too.  (too small to
merit an include file </facetious-grin>)  not having a "mathematical brain" I
found your code "amazing" but not as "obvious" as the method/algorithm provided
by Wikipedia.  also, it comes at a cost.  when running each macro ~20k times (5
loops over 1-3999 range) the nested loops are a little more "expensive".
regards, jr.
Date: 21 Dec 2025 05:47:15
Message: <6947d033$1@news.povray.org>
On 20/12/2025 23:53, jr wrote:
> hi,
20K is a lot, and double loops can be detrimental. You're right.
In fact, a long time ago, I was developing applications with FileMaker
and I had the same need. I just found my function and converted it to
POV SDL. Juste for fun ;)
kurtz le pirate
Date: 21 Dec 2025 07:35:00
Message: <web.6947e88e6fb404d152af7e976cde94f1@news.povray.org>
hi,
agree, unrealistic (I only wanted to get a(n approximate) "feel").
and that last is key.  last night I remembered that POV-Ray permits nested macro
declarations/definitions, and (fwiw) attach a text file with the code as adapted
"over breakfast" :-).  cheers.
regards, jr.
Download 'forfun.txt' (2 KB)
Date: 23 Dec 2025 11:59:29
Message: <694aca71$1@news.povray.org>
On 21/12/2025 13:32, jr wrote:
> hi,
for 20000 converts :
  * Elapsed time = 0.0202 ms for my macro
  * Elapsed time = 0.0162 ms for yours
you're the winner.
kurtz le pirate
