POV-Ray : Newsgroups : povray.general : Custom output filenames Server Time
17 Nov 2025 08:17:29 EST (-0500)
  Custom output filenames (Message 1 to 4 of 4)
Subject: Custom output filenames
Date: 14 Nov 2025 11:20:00
Message: <web.691755f9d7e726a667a60f225b085d4@news.povray.org>
I have a scene for which I want a number of different renderings (different
camera and light locations). I run a .ini file to render the variations, which
get numbered 0 to 49. In my .pov file I have the following code:
  #declare Rnd1 = seed(frame_number); // camera
  #declare Rnd2 = seed(frame_number); // light
From these 50 I select a number to render at high resolution, and I run a
different .ini file for these. In my .pov file I write the following code, which
maps the sequence numbers to my own:
  #declare frames = array[5] {2, 3, 5, 8, 13} // selected for high-res rendering
  #declare frame_nr = frames[frame_number];
  #declare Rnd1 = seed(frame_nr); // camera
  #declare Rnd2 = seed(frame_nr); // light
The result is a series of output files with filename numbers in sequence
(defined by the .ini file)
  outfile_00
  outfile_01
  outfile_02
  outfile_03
  outfile_04
Is there a way to have custom numbering for the output files? Like
  outfile_02
  outfile_03
  outfile_05
  outfile_08
  outfile_13
numbers I would get from the array in my .pov file, which would mean that the
output filename should be defined in the .pov file.
Subject: Re: Custom output filenames
Date: 14 Nov 2025 11:55:00
Message: <web.69175dddb2f6a36a475fba6a6cde94f1@news.povray.org>
hi,
>   outfile_02
>   outfile_03
>   outfile_05
>   outfile_08
>   outfile_13
not directly, afaik.  if you could use that "map" of frame->file# from a script,
the 'Post_Scene_Command' option will help.
<wiki.povray.org/content/Reference:Shell_Command_Options>
regards, jr.
Date: 14 Nov 2025 12:00:00
Message: <web.69175f42b2f6a36a475fba6a6cde94f1@news.povray.org>
sorry, 'Post_Frame_Command' is what I meant.
regards, jr.
Date: 14 Nov 2025 13:25:57
Message: <69177435$1@news.povray.org>
>    outfile_02
>    outfile_03
>    outfile_05
>    outfile_08
>    outfile_13
Not exactly what you asked for, but you can render single frames with
the animation frame subset capability via flags or ini options:
subset_start_frame, subset_end_frame, frame_step, +sf, +ef and +stp
   povray myAnimation.pov +sf7, +ef7 +kff10
would render just frame 7 of a 10 frame animation for example - with the
same frame animation output file name. You'd be running povray multiple
times change the subset options rather than using an SDL array, but if
not many high res frames perhaps not a bad approach.
Alternately.
Though I'm not a big fan of the capability due possible confusion, It is
also possible to set the 'frame_number' inside the SDL for your scene.
   #declare frame_number = 2;  // Or make '2' Ary[0] etc.
or set it - and the complete output file name - on the command line with:
   povray myAnimation.pov declare=frame_number=9 +omyAnimation09
Bill P.
