POV-Ray : Newsgroups : povray.beta-test : Collection of polygon object bugs / issues Server Time
21 Dec 2024 10:43:45 EST (-0500)
  Collection of polygon object bugs / issues (Message 1 to 1 of 1)
Subject: Collection of polygon object bugs / issues
Date: 11 Dec 2024 00:23:36
Message: <675921d8$1@news.povray.org>
References:
https://github.com/POV-Ray/povray/issues/467
"[BUG] doesn't give an error if a polygon is not 2D #467"
https://news.povray.org/povray.general/thread/%3Cweb.674a4c31296bdfa2e3cbe740b3ec8729%40news.povray.org%3E/
"polygon not visible"
While looking into a fix for the above issues in addition to extensions
to the existing polygon object functionality, I found additional bugs
and issues.
1) The automatic polygon closing feature creates confusing results as
often as it helps. It only works somewhat well for single loops of
points not yet closed.
2) In POV-Ray v3.0, the polygon object was re-written, substantially
upgrading its capabilities. Some guessing here, but it looks like the
effort started with an approach using a general projection of 3D polygon
points onto the x-y plane. Though there has long been the restriction
that the z values all be the same, the general code is still in there -
and it doesn't always create a valid initial transform /
inverse-transform 'transform structure'. In my testing it seems to
always work where the loops are all triangles - which is a fair
hint/guess as to what went wrong.
There are many rendering ameliorations which will lead to the bad
transforms going unnoticed. In adding certain features to yuqk's polygon
object I circumvented ALL of them. Users will mostly see things working.
  Especially when working on the polygon as a single object in
isolation. That said, I expect the bad transform the cause of some flaky
results over the years.
Today, the only 3D flexibility is where all z coordinates being the same
can indicate an offset along the z axis for the x-y plane - and this is
the transform structure which should be created. For the inverse
transform this a matrix:
   <1, 0, 0, 0>
   <0, 1, 0, 0>
   <0, 0, 1, 0>
   <0, 0, -z, 1>
and the transform matrix is:
   <1, 0, 0, 0>
   <0, 1, 0, 0>
   <0, 0, 1, 0>
   <0, 0, +z, 1>
The upcoming R17 (v0.6.11.0) of the yuqk fork hard codes these!
3) The 'transform structure' created by the v3.0 code has also been used
to flip direction of the normal based upon point order. However, bugs
aside, the transform creating code typically looks only at the first
four points of the first loop. This is not enough to reliably determine
the polygon's point loops rotation direction.
The standard method for this is a polygon area measuring algorithm often
called the shoelace formula. Release R17 of yuqk moves to this method
for setting the normal z direction.
4) There are a handful of checks in the code for the validity of polygon
point description. Most all since v3.7 were quietly marking the polygon
as an invalid shape which caused it to disappear. In the yuqk fork these
checks now all generate parse time errors on such failures.
However, there is a fairly large set of possible degenerate polygon
point descriptions for which there has never been any checking - and for
which adding checking is a chunks of work. This remains a TODO item in
the yuqk fork.
Bill P.
