POV-Ray : Newsgroups : povray.unix : G++13 Server Time
31 Oct 2024 06:14:41 EDT (-0400)
  G++13 (Message 1 to 3 of 3)
Subject: G++13
Date: 21 Jun 2024 22:45:00
Message: <web.66763a7d165794de9a328caa7597fb06@news.povray.org>
This week I updated my kubuntu 22.04LTS to 24.04LTS, and as a result I had to
reconfigure and recompile povray3.8 beta2.
To my amazement I got this error when running the new executable:
Parse Error: Viewing angle has to be smaller than 180 degrees.
After some DuckDuckGoing I found this solution
https://github.com/POV-Ray/povray/issues/460
and after replacing all HUGE_VALs into HUGE_FINITY_VALs my povray was working
again.
Is anybody going to change this in the povray source code, so that there will be
a new version with this patch?
More general, is there anybody, since Christopher Lipka left, still maintaining
povray?
What is the future of povray?
Is there a future for povray, or is 3.8 beta2 the last official version?
Ton.
Subject: Re: G++13
Date: 22 Jun 2024 01:35:38
Message: <667662aa$1@news.povray.org>
> again.
If the user posting in that issue was correct about g++13 turning on the
-fno-finite-math-only along with -ffast-math by default and it being the
cause of the problem, the safest thing to do is to configure with
-fno-fast-math (*) or use -fno-finite-math-only as suggested. (I cannot
reproduce the problem by turning finite-math-only on with my g++11.4
compiler...)
(*) - Many official linux distribution packages of POV-Ray run without
the fast-math flag, only O2 optimizations and some other stricter
compiler flags too. They play it safer with distributed software packages.
The wrong thing to do is use the suggested patch posted to that github
issue! It creates a new macro definition in source/core/configcore.h
called HUGE_FINITE_VAL which replaces the lines:
#ifndef HUGE_VAL
	#define HUGE_VAL 1.0e+17
#endif
with
#define HUGE_FINITE_VAL 1.0e+17
But, HUGE_VAL is always defined - for 25 years or more - in math.h /
cmath.h and not by that POV-Ray header file. In other words, we've not
been using that 1e17 value for eons - and the suggested patch brings
back that old value...
A real fix needs to look at and understand the cause and the code
implications in detail, everywhere HUGE_VAL* is used today(**). I know
we use +-inf, which are valid float/double values, to control code flow
in more than the one reported problem case.
(**) - The POV-Ray source uses std::numeric_limits too in places - which
has an inifinity() option. I bet those might be a problem too, if used.
The right fix for the camera code with the hard parse time fail is
likely to use std::numeric_limits<double>::max() over HUGE_VAL.
If finite-math-only is on in g++13 with fast-math by default (or due
whatever), I have to think we have more problems than the one, hard,
parse time camera error fail.
Aside: The linux distribution folks which opened the github issue have
backed up to g++12 for their distribution package.
I'm supporting my own playpen yuqk fork - and others too, theirs.
There is no official support as far as I know.
Bill P.
Subject: Re: G++13
Date: 3 Sep 2024 19:09:24
Message: <66d79724@news.povray.org>
> cause of the problem, the safest thing to do is to configure with -fno-
> compiler...)
Update.
I upgraded from Ubuntu 22.04 to Ubuntu 24.04 over the weekend. The
default g++ compiler is now 13.2.0 and builds do need to use the
-fno-finite-math-only flag when using -ffast-math (*) with g++13 builds.
Rather than the camera issue, with yuqk, I see the 'bounding not working
issue' issue reported in some fora here during the past year.
I expect given the different code bases, what will be seen as problems
with g++13 builds will be varied. This includes introducing problems
which might not be immediately apparent - the camera issues shows up
more or less by chance for example, because of a test not really in play
when it fails...
(I've not gotten around to re-building my collection of official releases.)
Bill P.
(*) - The default linux/unix builds with official releases use
-ffast-math. The yuqk fork as shipped does not assume any compiler
flags, but it does recommend -ffast-math with performance builds
suggested in INSTALL.txt.  (**)
(**) - I've only lightly read up on the current g++13 --fast-math
issues. However, it looks like gcc/g++ 13 plans to eventually back out
the library changes creating the POV-Ray g++13 build exposures.
Practically though, I think it best to always use -fno-finite-math-only
when using -ffast-math with g++13 given we might not 'see' all the
possible problems.
