![](/i/fill.gif) |
https://news.povray.org/povray.binaries.images/thread/%3C65c7ec42%40news.povray.org%3E/
Well, I found out why my 30th anniversary tribute to POV-Ray went crazy
when I upgraded the lamp fixtures: photons are broken with POV-Ray 3.8's
inverse squared lighting. I rendered my initial scene before I had
finished the DeskLamp module, and at that time, the scene used only
POV-Ray's legacy light fading; but the DeskLamp module automatically
uses true inverse squared if it detects #version 3.8 or later.
The 2 control images below were rendered without photons, just to verify
that the legacy light source and true inverse squared light source are
comparable.
---%<----%<----%<----%<--[BEGIN CODE]--%<----%<----%<----%<----%<---
// +KFF4 +W512 +H384
#version 3.8;
#declare Has_photons = (frame_number >= 3);
#declare True_invsq = 1 - mod (frame_number, 2);
#include "screen.inc"
global_settings
{ assumed_gamma 1
max_trace_level 100
#if (Has_photons)
photons { spacing 0.005 autostop 0 }
#default { finish { ambient 0.1 diffuse 0.6 emission 0 } }
box
{ -<6, 0.001, 6>, <6, 8, 6>
hollow
pigment { rgb 1 }
Set_Camera (<2, 3, -5>, <0.25, 1, 0>, 60)
#declare v_Source = <-5, 7, -5>;
#declare v_Focus = <0, 1, 0>;
#declare Dist = vlength (v_Source - v_Focus);
#if (True_invsq)
light_source
{ v_Source, rgb pow (Dist, 2)
fade_distance 0
fade_power 2
#else
#declare FD = 0.1;
light_source
{ v_Source, rgb (1 + pow (Dist / FD, 2)) / 2
fade_distance FD
fade_power 2
intersection
{ box { -1, 1 }
box { -1.1, 1.1 rotate 45 * x }
box { -1.1, 1.1 rotate 45 * y }
box { -1.1, 1.1 rotate 45 * z }
translate y
pigment { rgbf 1 }
finish
{ fresnel 1
reflection { 1 fresnel } conserve_energy
specular 1 roughness 0.0003
interior { ior 1.8 dispersion 1.04 }
photons { target collect off reflection on refraction on }
Screen_Object
( text
{ ttf "cyrvetic"
concat
( #if (True_invsq) "True inverse squared",
#else "Old fade formula",
#if (Has_photons) " with photons"
#else " control"
0.001, 0
pigment { rgb 0 }
scale 16 / image_height
<0, 0>, <0.02, 0.01>, yes, 1
--->%---->%---->%---->%---[END CODE]--->%---->%---->%---->%----%<---
Download 'invsq_photons1.jpg' (19 KB)
Download 'invsq_photons2.jpg' (19 KB)
Download 'invsq_photons3.jpg' (26 KB)
Download 'invsq_photons4.jpg' (37 KB)
Preview of image 'invsq_photons1.jpg'
![invsq_photons1.jpg](/povray.beta-test/attachment/%3C66732e0a%40news.povray.org%3E/invsq_photons1.jpg?preview=1)
Preview of image 'invsq_photons2.jpg'
![invsq_photons2.jpg](/povray.beta-test/attachment/%3C66732e0a%40news.povray.org%3E/invsq_photons2.jpg?preview=1)
Preview of image 'invsq_photons3.jpg'
![invsq_photons3.jpg](/povray.beta-test/attachment/%3C66732e0a%40news.povray.org%3E/invsq_photons3.jpg?preview=1)
Preview of image 'invsq_photons4.jpg'
![invsq_photons4.jpg](/povray.beta-test/attachment/%3C66732e0a%40news.povray.org%3E/invsq_photons4.jpg?preview=1)
![](/i/fill.gif) |
![](/i/fill.gif) |
At the time the photons feature was added, a significant part of the
tracing code was duplicated in the photons tracing code. When a trace
related feature is updated, we have to remember to duplicate the feature
update in that photons code.
I'd guess this didn't happen - at least not correctly.
I'll look at this tomorrow.
Bill P.
![](/i/fill.gif) |
![](/i/fill.gif) |
In source/core/lighting/photons.cpp there are two methods:
void PhotonTrace::addSurfacePhoton()
void PhotonMediaFunction::addMediaPhoton()
which have code like:
if ((photonLight->Fade_Power > 0.0) &&
(fabs(photonLight->Fade_Distance) > gkMinIsectDepthReturned))
Attenuation = 2.0 /
(1.0 + pow(threadData->photonDepth /
photonLight->Fade_Distance, photonLight->Fade_Power)
else
Attenuation = 1;
In both methods, the code needs to be something like:
if (photonLight->Fade_Power > 0.0)
if (fabs(photonLight->Fade_Distance) >= gkMinIsectDepthReturned)
Attenuation = 2.0 /
(1.0 + powf(threadData->photonDepth /
else if (threadData->photonDepth >= gkMinIsectDepthReturned)
Attenuation =
powf(threadData->photonDepth,-photonLight->Fade_Power);
else
Attenuation = 0.0;
else if (photonLight->Fade_Power == 0)
Attenuation = 1;
else
Attenuation = 0.0;
Bill P.
Aside: I moved pow to powf as the latter often much faster and float
accuracy is fine for attenuation. It might be official releases are
already running 'pow()' with floats without code that forces it.
![](/i/fill.gif) |
