POV-Ray : Newsgroups : povray.windows : Python, subprocess, error! Server Time
19 Jan 2026 15:03:11 EST (-0500)
  Python, subprocess, error! (Message 1 to 10 of 20)
Subject: Python, subprocess, error!
Date: 29 Jul 2014 15:30:01
Message: <web.53d7f4e6f9a4be657a3e03fe0@news.povray.org>
Hellow!
I want to make a render in a shadow mode for a preview of materials in Blender
In Linux - no problem, preview very good
In Windows don't work
http://blender-3d.ru/forum/index.php?action=dlattach;topic=753.0;attach=2930;image
pov_binary = os.path.join(win_home, "bin", "pvengine64.exe")
self._process =
subprocess.Popen(["%s"%pov_binary,"%s/Preview.ini"%previewDir],stdout=subprocess.PIPE,stderr=subprocess.STDOUT)
ini:
Version=3.7
Input_File_Name='C:\\povray\\preview\\Preview.pov'
Output_File_Name='C:\\povray\\preview\\Preview.png'
Width=100
Height=100
Bounding_Method=2
Display=0
Pause_When_Done=0
Output_File_Type=N
Output_Alpha=1
Antialias=on
Sampling_Method=3
Antialias_Depth=3
Antialias_Threshold=0.1
Antialias_Gamma=2.5
Subject: Re: Python, subprocess, error!
Date: 29 Jul 2014 19:05:23
Message: <53d828b3@news.povray.org>
Am 29.07.2014 21:24, schrieb LanuHum:
> Hellow!
It does tell you what's wrong:
"Cannot open INI file 'C:\povray\preview/Preview.ini'."
Make sure the file is indeed at that location.
Date: 30 Jul 2014 05:40:00
Message: <web.53d8bc654d559dd816086ed00@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> Hellow!
> self._process =
> ini:
> Version=3.7
> Width=100
> Height=100
> Bounding_Method=2
> Display=0
> Pause_When_Done=0
> Output_File_Type=N
> Output_Alpha=1
> Antialias=on
> Sampling_Method=3
> Antialias_Depth=3
> Antialias_Gamma=2.5
This Bug is now possibly solved in the official version, thanks for the report:
the preview directory was not created (since I had done it by hand while testing
and forgot to add it in the script later) You can download the corrected version
from the repository or any blender version built after  Monday, July the 28th at
8:02 PM.
Date: 30 Jul 2014 05:45:01
Message: <web.53d8bded4d559dd816086ed00@news.povray.org>
> > Hellow!
oh, it looks like something is wrong with the slash/backslash\ handling in the
report.  Can you let me know if the last version does work for you?
wheneverpossible using the os.path module methods to concatenate, truncate or
whatever one has to do with paths makes sure it works more smoothly across
platforms. possibly one slash should be removed from the hardwritten filename
and left to be handled by the python's os.path methods, for instance current
version is:
 workDir=os.path.dirname(__file__)
 previewDir=os.path.join(workDir, "preview")
 ## Make sure Preview directory exists and is empty
 if not os.path.isdir(previewDir):
 os.mkdir(previewDir)
 iniPrevFile=os.path.join(previewDir, "Preview.ini")
 inputPrevFile=os.path.join(previewDir, "Preview.pov")
Date: 30 Jul 2014 12:25:01
Message: <web.53d91c424d559dd87a3e03fe0@news.povray.org>
I changed all code. Now we use nodes and bl_use_preview = True
I have no Windows. After I will make changes, users will carry out the test,
then to me will tell
> version is:
Thanks!
Date: 2 Aug 2014 14:30:00
Message: <web.53dd2d5c4d559dd87a3e03fe0@news.povray.org>
Sorry.
There was a question: How to give command that Povray rendered without starting
GUI in Windows?
I looked for the answer in Google.
15 years users ask this question, 15 years you don't answer it.
The automatic exit after a render isn't necessary to me, it is necessary for me
that there was no GUI in general.
Preview function in a blender causes Povray constantly. Who needs GUI for a
preview?
The shadow mode is necessary.
Date: 3 Aug 2014 02:09:10
Message: <53ddd206@news.povray.org>
On 02/08/2014 20:26, LanuHum wrote:
> Sorry.
> GUI in Windows?
> preview?
No gui: try to have the unix/linux code in a windows port, via thing
like cygwin.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 3 Aug 2014 08:25:01
Message: <web.53de29984d559dd87a3e03fe0@news.povray.org>
> like cygwin.
There is no such option in Povray for Windows?
I will tell about it to users of Windows.
Let them study source codes and cygwin.
Date: 3 Aug 2014 14:32:57
Message: <53de8059$1@news.povray.org>
>> like cygwin.
The Windows version always show the GUI and there are now option or
switch to change that. The only thing that you may try is to start
minimised. It's possibly the same for the MacOS version.
Date: 3 Aug 2014 15:28:20
Message: <53de8d54$1@news.povray.org>
I would rather eat cake! :-)
Regards
