POV-Ray : Newsgroups : povray.windows : How do I make a torch shine? Server Time
16 Mar 2026 15:20:09 EDT (-0400)
  How do I make a torch shine? (Message 1 to 6 of 6)
Subject: How do I make a torch shine?
Date: 5 Oct 2013 14:50:01
Message: <web.52505e91b15a3c3ca3ea0a370@news.povray.org>
I'm relatively new to POV-Ray and I want to make a Minecraft-inspired cave
scene.
The only problem is: How can I make a torch shine or how should I define the
light source?
My torch is an object made of polygons, so I don't use a box or sth like that.
It would be nice to get an answer!
TMGellert
[ Here you find the POV-Ray Scene, if you need to see it in detail: ]
  // Minecraft TNT Block
  // TMGellert 05 Oct 2013
  //   I N C L U D E D   F I L E S
  //   C A M E R A
  camera { location <5, 2.625, -3> look_at  <2, 1.25, 0> }
  //   S T O N E   P L A N E S
  plane { z, 0 pigment { image_map {png "stone.png" } } finish {  } rotate 90*x
  plane { z, 0 pigment { image_map {png "stone.png" } } finish {  } translate
z/2 }
  plane { z, 0 pigment { image_map {png "stone.png" } } finish {  } rotate -90*y
translate <-0.5, 0, 0.5> }
  //   T N T   B L O C K
  #declare TNT_Base =
   polygon{
    4, <0,0,0>, <1,0,0>, <1,1,0>, <0,1,0>
    pigment { image_map { png "tnt_bottom.png" } }
    rotate <-90,0,0>
    translate <-0.5,0,0.5>
  #declare TNT_Side =
   polygon{
    pigment { image_map { png "tnt_side.png" } }
    rotate <0,0,0>
  #declare TNT_Top =
   polygon {
    pigment { image_map { png "tnt_top.png" } }
    rotate <90,0,0>
    translate <-0.5,1,-0.5>
  #declare TNT_Block = union {
   object { TNT_Base }
   object { TNT_Side                  translate <0,0,-1> }
   object { TNT_Side rotate <0,90,0>  translate <-1,0,0> }
   object { TNT_Side rotate <0,180,0> translate <0,0,1>  }
   object { TNT_Side rotate <0,270,0> translate <1,0,0>  }
   object { TNT_Top }
  object { TNT_Block }
  //   T O R C H
  #declare Torch_Side =
   polygon {
    4, <47/16,0,-1/16> <49/16,0,-1/16> <49/16,5/8,-1/16> <47/16,5/8,-1/16>
    pigment { image_map { png "torch.png" } }
  #declare Torch_Top =
   polygon {
    4, <47/16,1/2,-1/16> <49/16,1/2,-1/16> <49/16,5/8,-1/16> <47/16,5/8,-1/16>
    rotate <90,0,0>
    translate <0,9/16,-9/16>
  #declare Torch = union {
   object { Torch_Side                                     }
   object { Torch_Side rotate <0,90,0>  translate <3,0,3>  }
   object { Torch_Side rotate <0,180,0> translate <6,0,0>  }
   object { Torch_Side rotate <0,270,0> translate <3,0,-3> }
   object { Torch_Top }
  object { Torch }
Subject: Re: How do I make a torch shine?
Date: 5 Oct 2013 15:55:36
Message: <52506eb8$1@news.povray.org>
Note this newsgroup is for Windows-specific questions
(e.g. GUI, installation, command line parameters), you
might find more help in povray.newusers
> light source?
some pointers:
to make an object glow by itself in 3.6: Increase ambient in texture
to make an object glow by itself in 3.7 RC: Increase emission in texture
In both cases this will make the object appear bright. However,
it will not only illuminate its surroundings unless "radiosity" is
activated.  An alternative is to define a "light_source" at the position
where the torch should emit light. If the light source is within the
object you need to add "no_shadow" to the object so the light
can actually get out.
Date: 6 Oct 2013 05:20:00
Message: <web.52512a7f4256294aa3ea0a370@news.povray.org>
> > light source?
> some pointers:
Hm, I can't make this work. I can define the 'ambient' value but I struggle with
the radiosity setting. How do I write this so it could work?
Date: 6 Oct 2013 06:12:53
Message: <525137a5$1@news.povray.org>
Since you are new to Pov. If it were me, I would build your scene using
traditional lighting, until you get the hang of it. Personally I never
use radiosity as I've never had the good results that some people here
have. It is a subject on its own.
To get your torch to light and show a beam. You will need to use media.
You put a hollow container around your light source (hollow is a
keyword) and use scattering or emissive media. You will need to read up
on that, as well. :-)
Regards
Date: 6 Oct 2013 15:09:16
Message: <5251b55c$1@news.povray.org>
>>> light source?
>> some pointers:
For a start point using radiosity, just add radiosity{} in your
global_settings section.
This will turn radiosity on using default parameters. Those parameters
are a descent starting point.
If the torch flame have some transparency, just adding a regular
light_source inside ot will work, giving uneven and coloured illumination.
To get beter realism, you should use light fading. Add this:
fade_distance 1 fade_power 2
Adjust the light's intencity to get the illumination you want. There is
no upper limit to a light's intencity.
To further improve realism, you can concider using an area_light.
The following, added to your light_source definition is a good start:
area_light 1*x 1*z 9 9 adaptive 0 circular orient
Using adaptive is importent to greatly improve the rendering time. It
allow the use of a LOT of samples without slowing you down to much.
This make the light act like a spherical light with a diameter of 1 unit.
Example using both propositions:
light_source{
	<0,1.5,0> // the light's location
	rgb 100 // it's colour and intensity, adjusted for the fading
// physicaly acurate fading demand fade_power 2
	area_light 1*z 1*x 17 17 adaptive 0 circular orient
Date: 8 Oct 2013 06:42:44
Message: <5253e1a4@news.povray.org>
Also there is a convenient set of presets in rad_def.inc
#include "rad_def.inc"
global_settings
   radiosity {Rad_Settings(Radiosity_Normal, off, off)}
Replace Radiosity_Normal with, e.g., Radiosity_Debug,
Radiosity_Fast or Radiosity_Final as appropriate.
