POV-Ray : Newsgroups : povray.windows : Output_File_Name -- quoted string question Server Time
11 May 2025 07:39:34 EDT (-0400)
  Output_File_Name -- quoted string question (Message 1 to 10 of 16)
Subject: Output_File_Name -- quoted string question
Date: 12 May 2013 08:20:02
Message: <web.518f8756a19a1fd1c2d977c20@news.povray.org>
In Windows XP:
Could someone tell me what I'm doing wrong with the following quickres.ini code
that I'm using? It *works* OK (specifying a folder to put my rendered image in)
but I get an annoying non-fatal error message at the end of a render, "Most
likely detected an unquoted string with spaces in INI file..."  (Same behavior
in 3.62 and 3.7RC7) Sorry if the code doesn't fit on one line:
Output_File_Name=c:\Documents and Settings\Owner\My
Documents\POV-Ray\v3.6\tests\
I can see that there are "unquoted strings with spaces" (I think!), and I've
tried all sorts of quotes and slashes as a remedy; but they all cause one
problem or another. I've been living with this for years (and ignoring it); but
it's high time I fixed the problem.
Subject: Re: Output_File_Name -- quoted string question
Date: 12 May 2013 10:07:38
Message: <518fa22a$1@news.povray.org>
On 12-5-2013 14:16, Kenneth wrote:
In my own povray.ini file, I write these things between quotes:
Output_File_Name = "c:\Documents and Settings\Owner\My
Documents\POV-Ray\v3.6\tests\"
Date: 12 May 2013 10:33:46
Message: <518fa84a$1@news.povray.org>
Try
Output_File_Name="c:\\Documents and Settings\\Owner\\My
Documents\\POV-Ray\\v3.6\\tests\\"
This works for me.
Not that I use this method, myself. :-)
Regards
Date: 12 May 2013 10:36:07
Message: <518fa8d7@news.povray.org>
On 12/05/2013 3:33 PM, Stephen wrote:
> Try
> This works for me.
It also works with "\" instead of "\\" as Thomas posted.
Regards
Date: 12 May 2013 10:55:56
Message: <518fad7c@news.povray.org>
In some cases double back slashes are needed instead of single ones, I
found out by experience. In particular, when declaring names to be used
later in the code, like:
#declare Terragen_Sky_Name = "Terragen files\\Skies\\Pano_09_0h_50a_"
Not sure why that is though.
Date: 12 May 2013 11:24:27
Message: <518fb42b@news.povray.org>
"#include" paths need double slashes.
It must be different modules parsing the ini files and the pov files.
I would think.
Regards
Date: 12 May 2013 12:30:03
Message: <web.518fc21df34be07c2d977c20@news.povray.org>
Hey, this works!
I'm embarrassed to say that I tried this earlier...but I didn't run
an actual render to see what would happen!!  :-/  The reason being, that all of
the text in my quickres file that *followed* this line then took on the
appearance of being in string notation--like one *long* string, all the way to
the end of the file. (Rather hard to describe.) So I didn't pursue it, thinking
I had made a mistake.
That behavior is rather odd, to say the least--although it doesn't affect the
operation of the code.
Thanks!
Date: 12 May 2013 12:55:01
Message: <web.518fc73cf34be07c2d977c20@news.povray.org>
Stephen <mca### [at] aolcom> wrote:
> Try
This actually works even better; the double slashes eliminate the 'unending
string' behavior that the single slashes produce. Using this particular syntax
never occurred to me, though; the docs don't mention it.
But your suggestion gave me an idea: I'm guessing that the most 'important'
slash is the final one, preceding the last double-quote. My goofy intuition,
anyway, based on something I read in the docs. So I tried it a third way--
single slashes *except* at the end-- and it works as well as using all double
slashes:
Output_File_Name="c:\Documents and Settings\Owner\My
Documents\POV-Ray\v3.6\tests\\"
No error message, and no 'unending strings.'  Great!
Many thanks, to you and to Thomas. Mystery solved!
Date: 12 May 2013 13:53:33
Message: <518fd71d$1@news.povray.org>
IIRC it is the spaces in the directory names that cause the trouble.
There is or was, in a previous version, documented. But not under the
INI settings.
I am sure that I can speak for Thomas when I say, that it is our
pleasure to help.
Regards
Date: 12 May 2013 20:50:45
Message: <519038e5$1@news.povray.org>
> Thomas
The back slash is the escape character in strings. For example, "\n" is
used as a new line character, if you have \Skies\Pano,
it get parsed as "\s" "kies" "\p" "ano"
\s stand for the control character DC3 and \p for DLE
