POV-Ray : Newsgroups : povray.windows : Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bit. Server Time
11 May 2025 08:37:37 EDT (-0400)
  Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bit. (Message 1 to 6 of 6)
Subject: Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bit.
Date: 2 Feb 2012 16:05:01
Message: <web.4f2af963af7e52d7f8552de20@news.povray.org>
I am running Windows Ultimate 7, 64 bit on a dual CPU computer.  I already have
PovRay 3.5 installed in a Architectural program.
Do I uninstall the old PovRay 3.5 in the Architectural program first and then
install the updated version "PovWin362-64bit.msi," or can I install the update
over top of the old one?
Which update is best for this system, the PovWin362-64bit.msi or the Beta
Pov-Ray 3.7 for Windows?
Are the Pov-Ray 3.7 for Windows 32 or 64 bits?
Appreciate any help I can get. ;-)
ahed
Subject: Re: Help with updating existing Pov-Ray 3.5 to PovWin362-64bit in Win7 64bit.
Date: 5 Feb 2012 18:24:38
Message: <4f2f0fb6$1@news.povray.org>
Am 02.02.2012 22:00, schrieb ahed:
The step from 3.5 to 3.6.2 (or 3.7, for that matter) is not strictly an
update, but installs as a separate piece of software, so those versions
can live happily alongside each other. (It would be different if you
already had, say, 3.6.1 installed.) I would actually recommend leaving
the POV-Ray 3.5 installation intact, as the Architectural program may
not work well with the 3.6 or 3.7 versions.
On a dual-CPU or dual-core system, you'll definitely benefit from
POV-Ray 3.7's multithreading support. Even for a single-core single-CPU
system I'd recommend it, due to various other improvements too numerous
to mention.
(Just for clarity, the most recent POV-Ray 3.7 release is not labeled as
beta anymore, but as "release candidate 3", or "RC3" for short; that's
the one you want.)
POV-Ray 3.7 for Windows is available in both a 32-bit and 64-bit
version. As there are no known caveats with the latter, that's the one
you want.
Subject: Re: Help with updating existing Pov-Ray 3.5 to PovWin362-64bit inWin7 64bit.
Date: 5 Feb 2012 18:35:40
Message: <4f2f124c$1@news.povray.org>
> you want.
Surely it depends on the comms.dll? Hugo Arnaut (of Bishop3D) told me
that the 64 bit version of PovRay needed a 64 bit dll from the program
that calls PovRay.
Regards
Subject: Re: Help with updating existing Pov-Ray 3.5 to PovWin362-64bit inWin7 64bit=
Date: 7 Feb 2012 15:15:01
Message: <web.4f3185b85fe07293f8552de20@news.povray.org>
> > you want.
> that calls PovRay.
> Regards
>      Stephen
Have now tried most of the install variations.  I ended up reinstalling the
architectural program and leaving the 3.5 installed in that directory, then I
reinstalled the 3.7 win. 7, 64 bit in the default directory.  Where it wanted to
be was in C:\user\ahed\documents\PovRay\3.7.  Both work separately, so what line
can I change in the 3.5 Pvengine.ini file so it will chose the 3.7 over 3.5.
Thanks for helping me out
ahed
Date: 7 Feb 2012 15:47:39
Message: <4f318deb$1@news.povray.org>
you cannot tell povray 3.5 to use povray 3.7, that's not how it works.
You may be able to tell the architecture program to call povray 3.7,
although it is unlikely to work out of the box. How to change this needs
to be asked in the community of the architecture program.
Even on the off chance that someone here is familiar with this,
you'd have to disclose the name of the program first ;)
Subject: Re: Help with updating existing Pov-Ray 3.5 to PovWin362-64bit inWin764bit=
Date: 7 Feb 2012 17:52:09
Message: <4f31ab19$1@news.povray.org>
>> over 3.5.
Good answer Christian.
Ahed, if you say which program you are using them maybe someone can
download a trial version and help you.
As always, beating about the bush will not work.
Regards
